I know what you're saying and I'll try that. Seems to really fight me. Both tips push hard to the drivers side. The passenger side tip is really being a biotch. I don't recall this problem when I did this on my '16 Ram. I'll just have to work around it somehow. Don't like how it pulls left on both sides.
Start the truck and leave the exhaust warm. Once warm, wear gloves to prevent burning.
Handle one side at a time, start with drivers side. Loosen from the muffler and over axle connections.
Line everything up and tighten the over axle pipes, it’ll move. (Leave muffler connections loose)
Adjust at the pivot points on over axle connections left and right, To line it up off center. It’s best with a partner to assist looking at tips.
Helpful advice- take masking tape around the tips to prevent scratching while you adjust.
Make sure all the hangers are set evenly. If they are pushing, it’ll throw it out of alignment.
My catback seemed to favor toward the passenger side. But the passenger tip wanted to adjust to the license plate and wouldn’t straighten. It took me to adjust accordingly. There are only two pivot points, muffler connection and over the axle connections. It’ll take massaging but can be done. MF definitely needs to readjust their piping. Or make the tips adjustable ball/socket fittings. It would cure this all.
