- Apr 11, 2019
So, for the live features, the tazer has to stay plugged in because it’s modifying messages on the bus. It gets access to the bus through the security gateway connectors, while bypassing the SGW at the same time. Ultimately, that bus access point is via the 2 canbus junction blocks that all the modules are plugged into to communicate with each other, including the gateway. Disconnect the gateway from the bus, and tazer no longer has access to it for live features.Whoa. Just to make sure I understand this correctly…
When you install the Tazer, you unplug the SGW and plug in the Tazer as shown below. I assume this shield will cover the area. Are you saying that there’s a simple set of wires that can be snipped to disable all of that? If so, that would certainly make for a quick defeat.
I’ve got the Ravelco installed already, so this was just icing on the cake. Or not.
Most of the the attempted thefts where people have caught them and posted pictures paint the picture of what they are usually doing:
1) Smash the rear window so they don’t have to open a door setting off the VTA, and so they are not sitting in broken glass while they work.
2) Pop out the headlight switch to gain access to the canbus block.
3) plug their device into the bus and OBD port to pull the RFH PIN and program the fob (someone had a pic of a programmer left behind, but can’t find it right now). (The OBD port is not absolutely necessary as the device can be set up with its own small 12v power supply.)
