TruckDriver
Transport / Tire Jack / Alignment modes won't matter - the RC brackets are an alternative to putting in links which trick the truck into thinking it's lower than it is - causing the system to air up the front - effectively putting the front in OR mode all the time (hence the errors)I have these from RC. It works without errors as long as you don’t try to goto OR1 or OR2.
Adding the daystar pucks will help reverse the 'fake height' issue and actually, physically, lift the truck and correct the sensor angle simultaneously - which is the right way to do it
