I'm curios too. Bet you could tap the wire for the switch lights if the ambient harnesses aren't there.This thread about dash lights, but what about door lights? Anybody added it with cheap aftermarket LED’s?
More info on this idea... Seems the door switch lights don't dim with either knob. So keep that in mind.I'm curios too. Bet you could tap the wire for the switch lights if the ambient harnesses aren't there.
NIck, how do you install the glove box "tube" light? Do I need to remove the upper glove box? I read that it gets secured with a 5.5 MM screw, I don't see any screws in the vicinity of the mounting location.So I got the dash light pieces today and installed them. I've included pics of the dash before and after. the part numbers I used were two of the 68312667AC and one 68291948AC. Came in at just under $60 after tax. I would obviously look for the harnesses before buying the parts. Mine were hidden taped up inside around the main harnesses.Hope this helps and good luck!!
Do you have a “how to” on removing the glove boxes?Hey guys, I have 2021 ram Laramie. I saw the post that SOWARDCUSTOMS posted. I popped out the drivers side AC duct to look for the connector. There is a fat wire harness next to the duct. I felt a bump in the harness and removed the cloth tape. There I found the connector. I removed the radio console and found the other 2 connectors. one by the start/stop button and one by the upper glove box. The parts you need are two 68312667-AC for both sides of the steering wheel (same light) and one 68291948-AC for the glove box. They are all plug and play. I spent around $60 on the parts. The glove box light comes with a long clear tube to carry the light across the top of the upper glove box. The bad part is you have to remove the upper and lower glove box to install this tube. Not hard at all. took me about 1.5 hours because I had to figure out how to get the glove box out . I could do it in about 40 mins now (not counting bandaid and smoke breaks) that I know how to get the glove box out. Here is a link to a guy who changed his leds to blue. Just fast forward till you get to the dash part. I think they look cool and i'm going to change mine as soon as they become available again.This second link is for the PARAGOPTICS instructions. https://drive.google.com/file/d/1r96cHf7pv-VYaoIGrUSWuMTmiUlJbRrP/view Between the two links you should get a pretty good idea of how to do it yourself. Hopes this helps.
Just got my 22 Laramie GT and passenger foam insert is not there, neither was the sticker on back window indicating Ram Air Suspension, but dealer ordered it for me at no cost. Guess I’ll ask them about the insert because it’s on the sticker.My 2021 has both foam inserts. Maybe because it's a Limited or maybe some other reason. Ram has been inconsistent with the foam inserts on 5th gens. There have been a few threads discussing this.
You don't have to remove the glovebox. it will slide in. It is a PIA to get though. It will take a few times to get the angle just right so it won't pop out on you while you're putting it in. Once it's in it won't pop out on you though.NIck, how do you install the glove box "tube" light? Do I need to remove the upper glove box? I read that it gets secured with a 5.5 MM screw, I don't see any screws in the vicinity of the mounting location.
I assume there is a channel it slides in? And the light gets bolted in? Or does in snap in?You don't have to remove the glovebox. it will slide in. It is a PIA to get though. It will take a few times to get the angle just right so it won't pop out on you while you're putting it in. Once it's in it won't pop out on you though.![]()
I haven't done this mod, but it looks like the light isn't fully seated towards the end causing more light to show. Does it just pop in place?I added the ambient lighting to my truck and cannot get the glove box to light evenly. Tried rotating the tube and even covering the end of it. There’s a bright spot on the far right. Does anyone have a pic of a factory equipped one lit up?
I posted some before and after pictures earlier in the thread. This is seated correctly.I added the ambient lighting to my truck and cannot get the glove box to light evenly. Tried rotating the tube and even covering the end of it. There’s a bright spot on the far right. Does anyone have a pic of a factory equipped one lit up?
