MannymanX
5thGenRams Supporter
AzZona
i did this conversion from 8.4 non nav to 12.1. everything works except the ac and heater don't blend . its either hot or cold. is everyone else experiencing this? Is there a fix?
Yes, give the truck a couple hours… the modules are still syncing with each other.
Heavyhauler85
Hey guys been following the thread! LOTS of info! Sooo I have a 2021 Ram Laramie with an 8.4 W/NAV.. did the repin, installed and used the OBDMX+ with alphaOBD, changed the ICS(CENTERSTACK) to Disable And the DCSD To ENABLE.. now i gotta wait a couple hours? Or do i disconnect the battery and reconnect and wait? RIGHT NOW... BACK UP CAMERA.. XM ANDRIOD AUTO and Volume and Tune buttons DO NOT work. My clock/time is not synced with my GPS...
MannymanX
AzZona
Disconnect the battery and wait for 15 minutes, then reconnect it. Then the “couple hours” starts…
Heavyhauler85
Ok i let my truck sit for about an hr i had to go run an arrand but i did not disconnect the battery after the bcm reprogram. During that drive time i noticed the knobs work, xm works( but not subscribed although i am paying for a plan) AND the back up camera does not work.. and ANDROID AUTO gives me Communication Error 8
MannyN
You have to call SiriusXM and tell them that you replaced your radio and give them your new radio ID. They will send you a refresh signal and XM should work.
Nieto91
Did the back up camera work for you?
Heavyhauler85
Nope.. EVERYTHING ELSE WORKS now.. ANDRIOD AUTO works too.. i did a HARD RESET on the BCM with AlfaOBD.. reprogrammed BCM with the new settings for ICS(disabled) and DCSD(enabled) let yhe truck sit for a day and it all works EXCEPT the backup cam.
NOTE..... backup cam ONLY works if i put it in reverse within the first 5 seconds of turning on the truck or before pressing the "ACCEPT button"**SOMETIMES**.... sooooo the truck reads it and it knows its there... but I HAVE NO IDEA why it doesnt work. If i press the backup cam app i juat get a blue screen. Maybe its a sync/waiting game?? Can anyone chime in?
Nieto91
FDE294FF-A762-42CA-B744-D0E8C4F4D1D0.png This guy was saying something about it’s the module that we have to get a different one for the 2021 I have the same year 2021 and im having the same problem but in mine I just get a blue screen when I click on the camera app but it doesn’t activate when I put it in reverse at all
Heavyhauler85
View attachment 117383 This guy was saying something about it’s the module that we have to get a different one for the 2021 I have the same year 2021 and im having the same problem but in mine I just get a blue screen when I click on the camera app but it doesn’t activate when I put it in reverse at all
Check out my pics... within 5sec if dont turn it on via remote start... i can drive it in reverse for an hour and it will work.. but once i put it in drive it wont work for that key cycle. MAYBE it might later on HOPEFULLY
Nieto91
Could be just wait it out this here is mine you can see the reverse is on but it doesn’t even come on and when I click on the app it shows a blue screen AA9247A6-8E24-4513-B704-3C3CB714D4E2.png 4D2D0E86-FFF0-4054-9C9D-D6049339356F.png
Toperz
Stratford, CT
Could be just wait it out this here is mine you can see the reverse is on but it doesn’t even come on and when I click on the app it shows a blue screen View attachment 117401 View attachment 117402
Double check module part you got its definitely different then 19-20. Mine swap works with no problems. I got this:
68472372AERADIO. MULTI Media.1$910.20
and in my situation I didn't have to wait even 15min for everything to work.
Nieto91
The one that i have is 68317978AL and everything work with no problem at all like the buttons work fine and didn’t have to wait either or anything but the only problem was the camera
Nieto91
I just bought this 68472372AI it’s the updated version of the one
I just bought this one 68472372AI it’s the updated version of what you have
Toperz
Stratford, CT
Maybe recheck connections, I had small issue(don't remember what) but one of the plugs were not pushed in fully.
Heavyhauler85
My part# 68317978AG
Ima try and recheck all connections. Like i said, my backup cam only works within the 1st 5sec of starting the radio or sometimes not at all. Seems like a software issue, cause the hardware works... but im going to give it some more time. Just finished a 700mile drive on it. I love it! Just the backup cam issue.
Nieto91
My part# 68317978AG
Well I haven’t got back I rechecked everything on the 68317978AL module and I had it for 2 weeks and nothing with my back up camera I order the 68472372Al as I mention to you what someone said and when I changed it every worked quick like less then 10 mins my back up camera was working in reverse and thru the app on the screen I can say it was a successful working mod what about you have you got it to work good?
Nieto91
That was my problem I had the wrong module but now that I got the right one it work right up straightforward like you said mine was less then 10mins
Cesar592
yours works in 19-20 and I had to buy this one that is only for 2020 what will be the difference apart from the price
