BDS 2” Coilover Leveling Kit with 295/70R18
jan_riefkohl
Puerto Rico
I’m making this thread since I haven’t seen anyone talking about this kit. The 1664F comes preset to 2” of lift but can reach 2.5” safely, fox recommends not to go above that. They perform perfectly at 2.5” but you might get spring bind at 3”.
Heard back from Fox that the full 3” will not cause spring bind and I will be fully lifting the truck to remove as much rake as possible, I’ll post more pictures after.
On my build I added Icon 1.5” Lift Springs on the rear because I had already ordered them, this brings the rake back but minimal at 0.75-1”. If you are towing or hauling this will benefit you.
I mounted wheels and tires to my build with the Fuel Torque 18x9 with a +1mm offset and Nitto Ridge Grappler 295/70R18. To fit these tires with this offset you will have to slightly trim plastic and bend a metal piece of the mudflap.
All in all the truck sits great at this height and the stance is perfectly flush with the factory fender flares. The suspension is out of this world and performs a lot better than factory.
JerryBsizzle
Hey that's very nice. If I "built" one I think that is the exact build I would want. I like what you've done.
jan_riefkohl
Puerto Rico
Hahaha, thank you. Yeah it sounded off to me too when I wrote it but didn’t know what else to put, if you got any suggestions I’ll change it.
Carl
Heard back from Fox that the full 3” will not cause spring bind and I will be fully lifting the truck to remove as much rake as possible, I’ll post por pictures after.
yep you nailed it.
jan_riefkohl
Puerto Rico
yep you nailed it.
Thank you! Having an issue with something clanking in the rear and I have no idea what it is. Checked all the bolts on the suspension and the end links, control arms, and track bar, and I haven’t found the source yet.
TriSum
How do you like the Ridge Grapplers? How is the noise on the highway? I travel back and forth between SoCal and Phoenix and don't need to listen to tire noise the whole way. Truck looks great! I've been looking at this kit since the Carli Commuter isn't available yet.
jan_riefkohl
Puerto Rico
The only other tire I’ve heard are the BFGoodrich KO2s which are all terrain vs the Nitto Ridge Grapplers which are hybrids, based on what I read on the website the Nittos are supposed to be quieter than others due to it tighter tread pattern towards the center of the tire and I can say this is very true. Lower speeds like 30-50 you wont be hearing them at all. Higher speeds like 60-80 you might hear a bit. So that you can get a picture, the AC will block the sound out as well as having music on at normal volume.
jan_riefkohl
Puerto Rico
I was looking at the Carli Commuter as well but due to the fact I had ordered separate components to build a Bilstein kit and they never arrived I burned the 2 months I was willing to wait for. During this time the Carli didn’t show any updates so I decided to go with BDS since they had full inventory of the kit.
TriSum
Did you get the standard coilovers or the DSC ones? Still trying to decide on the Commuter, Icon or BDS. Just looking for the best on road ride, no off roading.
jan_riefkohl
Puerto Rico
If you want the best on road but maintain a soft ride I’ve recently recently read from a post by [mention]Mclovinnnnn [/mention] that the Fox 2.0 are amazing.
The BDS kit will make the ride a bit stiffer and you’ll feel the road more as they are tuned for a hybrid driving style (moderate off road to harsh).
I went with the standard coilovers. I did consider the DSC upgrade but ultimately decided for the standard as I would 99% of the time be on road. In my honest opinion if I wasn’t going to be running DSC on all four corners it wasn’t worth the investment. My thought is that the rear would counter act what the adjustment in the front is doing.
If you want the ultimate road ride and have the $330 extra to spare go for it, I have no idea if you would benefit from the adjuster in the front as the rear would remain the same.
I love how my truck feels at the moment and if I ever want the DSC I can purchase them for $330 each from FOX.
TLDR if you are only going to be on road I don’t think you’ll need the DSC especially since you wont have it at the rear.
In regards to the brand
Icons packages although good I feel they are a bit overpriced for what they include and they are missing things I could want especially at the price point that matches the BDS. Also you would only get 1.5” lift from them.
Carli commuter is taking forever to be released but would be an excellent choice if you don’t want reservoirs and you want the same lift as the BDS.
bfabian76
can you post a part number or link to what you bought? the FOX coil overs i see are 0-2 inch lift? are there better ones?
jan_riefkohl
Puerto Rico
The BDS kit uses the Factory Race Series of this part number: 883-06-166. Again, this part number is the Performance Elite version but the BDS kit uses the superior Factory Race version.
bdhouston1
Sent from my iPhone using Tapatalkrh
Thanks for all the great info:
I am also needing some advice or whether to go with the BDS 2” coilover level or the carli commuter 2.5 (have they released yet?)
Have a 2022 Laramie 1500 v8 inbound.
looking at the fuel Ammo D700 wheels and the nitto terra (Any advise on size of wheel and tire with said leveling)
thanks in advance for the help!
jan_riefkohl
Puerto Rico
Haven’t checked the Carli Commuter in a while so can’t say. I love my BDS kit, I’d say 18” wheels is the perfect size if you want meaty tires, 34” is the limit if you only want to do very slight trimming (cutting a corner of the mudflap). You could go 35” if you are willing to completely remove the front mudflaps as well as cut the metal bracket that holds it.
bdhouston1
Your info is great
thinking of 20x9 fuel D700 ammo
33x12x50 Nitto G2 (should work out to 275-65-20)
thoughts or suggestions before I pull the trigger?
I will go with the BDS coilover… have only heard great things and you just confirmed that
thanks again!
jan_riefkohl
Puerto Rico
Your info is great
thanks again!
What offset would de D700 Ammo be? Since you are putting a wider tire make sure you clear the control arms. Tire height is fine. And with the wheel size you wont have any issues with the balancing weights hitting the brake calipers.
bdhouston1
Offset would be +1
Any thoughts how this build up would fit the wheel well and would there be any outset from the fender of the tire?
thanks!
jan_riefkohl
Puerto Rico
Offset would be +1
thanks!
You have the same offset as me so you should be fine. With my current offset and tire I sit flush with the fender, that being said I do have factory fender flares. If I were to put your tires on my truck I would sit 1 inch outside of the fender.
RamRod187
Offset would be +1
thanks!
So I’m doing very similar to what you want. I have a 2021 Laramie and having the Rough Country 2” leveling kit (loaded strut) installed with 18”x 9” Fuel Ammo D700 in Blackt with with +1 offset and Mickey Thompson Baja Boss A/T LT295/70R18 installed on Thursday the 20th. I can let you know what/if it rubs and post pictures. Some people say it rubs and others don’t with same size tires and similar offset. But I definitely have read 12.5” wide with that offset and just leveling kit will rub
currently my front is 2” higher than the back and I have the 6‘-4” bed
jan_riefkohl
Puerto Rico
I’ve seen that the Thompson’s are pretty aggressive just like mine so you might rub on the mudflap on full lock. And FYI do NOT let them put balancing weights inline with the calipers or they WILL rip off and scratch the inside of the wheel. Have them put corner weights.
