jan_riefkohl
I’m making this thread since I haven’t seen anyone talking about this kit. The 1664F comes preset to 2” of lift but can reach 2.5” safely, fox recommends not to go above that. They perform perfectly at 2.5” but you might get spring bind at 3”.
Heard back from Fox that the full 3” will not cause spring bind and I will be fully lifting the truck to remove as much rake as possible, I’ll post more pictures after.
On my build I added Icon 1.5” Lift Springs on the rear because I had already ordered them, this brings the rake back but minimal at 0.75-1”. If you are towing or hauling this will benefit you.
I mounted wheels and tires to my build with the Fuel Torque 18x9 with a +1mm offset and Nitto Ridge Grappler 295/70R18. To fit these tires with this offset you will have to slightly trim plastic and bend a metal piece of the mudflap.
All in all the truck sits great at this height and the stance is perfectly flush with the factory fender flares. The suspension is out of this world and performs a lot better than factory.
