Yup :( and the location it’s leaking suggests it’s the window frame and not third brake light. Mine leaked on each side of the rear sliding window and after replacing the 3rd brake light seal that went away.
Sure the hell is. I have the same problem , awaiting an appointment at the dealer to get it resealed
Ugghhhh! I really don't want to be dealing with the dealer... I've probably opened my rear window less than a handful of time because I was trying to avoid this.
Is it related to that? I thought it was related to the window frames cracking or not being sealed properly, I use my rear window all the time and I’m at 33k miles.
Go to a glass shop and have them run a bead of urethane in the channel between the window and the body.
Unless its something expensive or labor intensive, I'm avoiding the dealer
It has nothing to do with whether the window is open or closed. Not a good reason not to use it
For some reason I thought it was, I thought I had read about it somewhere.
I need to unbookmark this thread. Each time I see a great mod posted, it makes me want to spend money, and get more mods. But some how, I just don't want to unsubscribe...lol.
2021 Ram Rebel
2016 Dodge Charger scat pack
Great job!
Same here. This forum is the cause of me spending thousands of dollars. I had no plans on modifying the truck at all before I found this place.
Spending money I don't have on parts I don't need to impress people I don't know
Same, I hate dealing with my dealership especially now that the truck is modded a Ton.
Big improvement! Cabin noise is down alot, but also both my factory sub and aftermarket sub output has drastically increased!
I did put some polyfill in the factory sub box and some sound deadening on the back. That thing is the lamest excuse for a subwoofer ever.
i know what you mean.i got rid of mine and made my own!
Picked up the truck from the shop. Got the 4inch bds air ride on, wheels, 35x12.5 nitto ridge grapplers, rotors, installed. Very very happy with the way the truck turned out. Haven’t stopped driving it since picking it up!
Don't be selfish. Stop long enough for some pics. 😁
