Actually, mine is 1069...so it's a 72 lb delta. This doesn't mean I'm winningLovely, I was not aware my payload were a record low. At least mine is 45 pounds better then @SpeedyV![]()
Yes, I seen it was a sport, which is why I have sport after your name, but it is based off the bighorn...guess I could have listed it differently, but I just added it in that category.Mines not a bighorn. It's a sport model only in Canada. Mines pretty loaded with options that's why my payload is lower.
Wow! Didn’t’ expect to be on the high end per trim level. Nice post. Out here in the wide open, as long as I’m not going down the road to far or if I am only in the fields and pastures the payload max weight is whatever I say it is.
Funny my Rebel is 1446 lbs. I have it fully loaded (included sunroof and air suspension), only thing I didn't get was the Rambox.
This thread had me thinking about overall abilities of our trucks, and man ohh man, am I ever happy I have the 3.92 - I still can't believe there's a 3,100 lb towing capacity difference - that's definitely the best $50 anyone will spend in my opinion.
The Official Towing Chart from RAM identifies our trucks with the 4x4, 5.7 Hemi, 3.92, Crew 5.7 box capable of towing 11,340 lbs and a max payload of 1,840 lbs (see attached snippet).
What's interesting is the BSG (e-torque) makes you lose 90 lbs of towing capacity - I guess that e-torque and batteries take a bit of extra weight, BUT this also affects your payload too! So if I had e-torque, I would have had a payload of 1, 356 lbs (based solely on my truck's trim and options - my payload is 1446 )?
Or
I guess it would be 1,336 since the e-torque payload is 1, 780 instead of 1,840? since I would need to add 60 lbs, and already lost 394 lbs of payload. Follow?
Based on the difference in total weight; 63 lbs (they say 60, but the base weight is more accurate) less payload based on total weight difference?
I'm wondering how this should be interpreted, because the e-torque seems to affect both payload and max towing. The weight in front is heavier and in the back lighter too...
The ETorque set up is about 90lbs of equipment hanging on the motor and firewall and including the battery weight. That would explain it.
Thats why i ordered mine no e-torq and with air suspension because coil springs ads 70 pounds of payloadYep for sure - and it definitely has an impact on your payload.
6900 for 2wd@Daniel What cab and bed is your Bighorn? I have been looking at some CC Bighorns that have the 6'4" bed and was trying to figure out close to what the payload would be. Aside from air suspension and front bench seat, the ones I am looking at seem pretty close to the setup you have. Also, is it 4x4 or 4x2? I think the 7100 GVWR only applies to the 4x4.
Quad cab 6.4 bed, 4x4 7100 - truck weight 5074= 2026 payload6900 for 2wd
Did you post your sticker...nothing showed upHere is my payload sticker
