One BIG bump (like a rough railroad crossing), and you may decide you really like it!About 75-100lbs less than expected. I really hope I don't regret the air suspension.
@MrHankbot any trips planned soon or a dry run. Very anxious to know what you come up with. Since we have similar thoughts about the 1500 2500 debate
Well, I would say you could loadthe truck up with the 100lbs you lost over the pilot and the truck will perform better.
I don't know if you seen my other post, but when searching for an answer to another members question, I came across info that the air suspension was rated for 2000lbs...no confirmation though.
So since we haven't seen a Ram with over 1800ish...I an thinking your setup might fall right into the parameters.
Good luck. Hope it works.
I saw that too, my fear is that it's like the 1840lbs of payload* where it's on a bare bones truck, and so we've lost a big chunk of that 2000lbs with all the extra gear on our optioned out Limiteds and Longhorns.
As long as I never get the overweight message if I'm just 100-150lbs over my 1300lb payload, then all is well. Obviously I'll be working to avoid that situation, but it's a truck, it was bought to work hard when we need it to.
here is my stickerFirst V6 stickers! View attachment 7465 View attachment 7466
What are the specs of your truck? It will be helpful for everyone if you would just list that in your signature block.here is my sticker
No, not for the truck you have. Some have lessIs this unusally low? I flipped through a few pages on this thread and I think it's the lowest I've seen. View attachment 7760
For comparison, this 2019 F150 Limited has under 1100lbs payload and a very high price tag.
