Def think that's the error issue... you also may have to add two pinned wires from the wiring block under your drivers seat to the module in the kick... you can check if you need them by looking at the grey plug at the module and see if all cavities are full...
68360453AD --- this is the rear harness with the passive antenna connector
-=FM45=-
-=FM45=-
