Hellwig Sway Bar Purchase$$$$
Mountain Whiskey
Your comment surprised me so I called Hellwig a moment ago and the rep told me it is supposed to point down. I asked her if they are a non-directional bar whereupon she replied they are direction and it needs to be pointed down just like the one that was installed at the factory. I asked if this was stated anywhere in their instructions or on their website as my doesn't state this but I was told it should point down thus I installed it that way...her response was it does not state it anywhere but it should be pointed down.
To each their own...and I'm not saying your right and I'm wrong or vice versa - just that Hellwig can't seem to put out consistent information. I hope the quality control of their bars is better than their information control.
So are you saying it should be pointed down? Not up, right? Down?
NorthStar
Texas
The center of the sway bar that goes behind the pumpkin should point downward, not up. I simply replicated the way my Mopar sway bar was installed by disconnecting it from the truck and dropping it to the ground. I then overlaid the Hellwig and installed it in the same orientation.
If it’s incorrect, it’s because they installed it wrong at the factory and Hellwig failed to provide clear instructions! :)
IvoryHemi
Your question got me thinking. I think the air suspension does provide a firmer effective spring rate while towing (evidenced by the lack of sag even with a substantial tongue weight). That firmer spring rate could provide a more stable ride when towing. Could be why I’m not feeling any significant stability improvement while towing. Just a theory.
Thanks. Only reason I would get it is for towing, so I may just pass on this then
redneck
s.w florida
i have the air suspension & 4x4 my factory sway bar was solid & just as heavy as the hellwig i bought it anyway & installed it on the stiffest setting & no change
Neurobit
RAM Sorcerer
Texas
Really? My 2019 OEM sway bar was hollow and about a third of the weight of the Hellwig.
Do 2021s come with beefier ones now?
securityguy
North Florida
Are you sure about that??? The sway bar is the sway bar regardless of trim level and suspension and the OEM bar is far lighter and not nearly as "solid" as the Hellwig.
Jeffjad
Southwest PA
Yep I guess the 21 longhorns changed the factory sway bar cause it's solid it is 1/8 smaller in diameter Than hellwig and I didn't notice any difference in trailer sway.
I'm not trying to be a di** but I still call BS. Throw those bad boys on a scale for weight comparison and let me know what the difference is.
