JbVt
- Jun 2, 2020
Second that!Really nice looking setup! How do the UCA angles look with the mopar lift UCAs? Setting #5 of the front bilsteins?
Thanks! The angles look better and more than worth it for peace of mind and cost. Setting #5 on the Bilstein as the max with the ORP springs.Really nice looking setup! How do the UCA angles look with the mopar lift UCAs? Setting #5 of the front bilsteins?
Anyway you could snap a photo of the uca? Thanks!Thanks! The angles look better and more than worth it for peace of mind and cost. Setting #5 on the Bilstein as the max with the ORP springs.
Love this look! Well done sir!First post, here we go. Before and after pics attached. Love it so far, happy I went with 20s and not the 22s
2020 Ram Laramie sport night edition
Readylift 3.5” SST
20X9 XD820 Grenade Blk/Mil
35X12.50R20 Nitto Ridge Grappler
Question, and pardon my ignorance (first truck), if the front rake is about 2", how are you leveling with Bilsteins? Thanks.....I am thinking about doing the same and was considering only front Bilstein's but might want to just do all 4.Bilstein 5100’s front/rear set at 2.2” and Nitto ridge grappler 295/70r18. Stock wheels. I’m happy with it. Still rides beautifully.
Bilsteins have 7 settings you can choose from that provide different lift heights in the front. No rear lift. I plan to do bilsteins and I’ll swap the backs while I’m working on it. Better struts than OEM anyhow!Question, and pardon my ignorance (first truck), if the front rake is about 2", how are you leveling with Bilsteins? Thanks.....I am thinking about doing the same and was considering only front Bilstein's but might want to just do all 4.
Thanks and that makes sense. Reading @Ryan RVA post, he indicated he set "Bilstein 5100’s front/rear set at 2.2”, which sounded like he raised the front/rear 2.2"....Bilsteins have 7 settings you can choose from that provide different lift heights in the front. No rear lift. I plan to do bilsteins and I’ll swap the backs while I’m working on it. Better struts than OEM anyhow!
Here’s the lift heights chart. I don’t think you actually get the amount of lift it shows. It’ll be close but it could differ slightly!Thanks and that makes sense. Reading @Ryan RVA post, he indicated he set "Bilstein 5100’s front/rear set at 2.2”, which sounded like he raised the front/rear 2.2"....
What setting are you running?
I've got them cranked up to 2.6". I thought I had the off road package, I don't. I have the undercarriage protection group, not the stiffer springs.What setting are you running?
What setting are you at and how are the mopar ucas working out?
Looks great!!2019 Ram 1500 Bighorn
Front Suspension: Bilstein 5100 Front and Rear Shocks
ORP Front Springs
Mopar UCA’s for lifts
Rear: Motofab Rear 1” spacer
Wheels: XD XD842 Snare 20x9 0
Tires: Federal Xplora RT 35x12.50R
ORP Front Springs
Cranked up all the way to 2.6"What setting are you at and how are the mopar ucas working out?
looks great what's your set up?Got the wheels on yesterday
