Did you ever work for University of Illinois?2019 Ram Rebel Blackout Edition, Retrax Tonneau cover, Elevate Rack System, AMP electric running boards, OEM bed light kit, OEM tailgate strut, Tuff Stuff 4X4 Alpha Overland Tent and annex, Factory spray in bed liner
How were you able to fit the bracket between your receiver and your bumper, did you remove the bumper?? I have the same mount set up on my truck and actually had to cut the top of the mount in half for it to fit, surprisingly it still holds up very well despite that.Just finished prepping my truck for the rear bumper reverse flood lighting I purchased. All wiring was done with a CURT harness and all wiring has been installed in split loom tubing. Once the mounting bracket arrives, I'll finish her up and post pics!
UPDATE: OK...off to a great start being that it rained on and off today and my hitch bracket just came about an hour ago. I have the bracket installed; the lights mounted; the CURT harness connected up to the truck; the 5-pin extension cable wired up; and all wiring is in a split-loom jacket. If the weather holds out tomorrow (calling for more rain), I plan to get everything wired up and functional. Pics so far:
View attachment 82774View attachment 82775
I decided to to be REALLY controversial and go w/ (5) grill lights! I know ... my Ram NEEDS a bath AND Whiskey Tango Foxtrot ... DIAL DOWN THE FRIGGIN DRLs (Dorky Ridiculous Lights)!
That indeed is the RC Hidden Lightbar. I had a Diode Dynamics Installer install it. The amber DRL LEDs and white driving LEDs were wired per the RC instructions. He did say that the instructions had a bit too much info regarding the installation of the mounting bracket. And I was initially going to wire the grill DRLs to the wires of the RC DRLs, but when I did, they did not illuminate. I measured the RC DRL output and it was < 8 V, I believe, so too little output for the grill DRLs. So I wired them separately and simply used a wireless controller for a separate relay to turn on/off.Is that the Rough Country light bar with DRL in the grill? I’ve been looking at those for weeks, on the fence about ordering. How was the install process? Did you wire DRL portion to your DRL circuit or are you turning on manually?
tell me that ice is in elpaso
5 Lights! You are really walking the edgeI decided to to be REALLY controversial and go w/ (5) grill lights! I know ... my Ram NEEDS a bath AND Whiskey Tango Foxtrot ... DIAL DOWN THE FRIGGIN DRLs (Dorky Ridiculous Lights)!
PICS? WHAT P/N DID U USE?Installed the AVS low profile in channel window vent shades. Hoping that they seat well and mold into the channel so the windows don't auto reverse.
Which flares are those? I have a bighorn and have really been contemplating tackling this. Thanks.Finally installed some fender flares. Black for now, may get them painted to match later, we'll see how I feel about them
View attachment 82827View attachment 82828
I just KNEW I should have added that info initially!Did you go with a speed tech lights wireless controller?
There's 3 per pack. BUT because the "standard" is 3 lights (Raptor, Rebe;l, TRX) I wanted to let others know I don't have a hell-raising, off-road BEAST. So I decided to go "big" (bright???) or go home!5 Lights! You are really walking the edge![]()
I just got the same step hitch for mine. Did you splice it into the factory harness underneath or how did you wire yours up?The best $69.95 I spent on the truck so far! I came out to the parking lot after going into the store and I saw that some some jack *** backed into my truck. It was a hit-and-run. No note. Thank God I had this hitch step that I use to get into my truck bed with the multifunction tailgate. It just saved me a lot of money and repairs!
I will get pics after it gets a wash, plus I want to check for any noise or leaks. I got AVS P/N 994064PICS? WHAT P/N DID U USE?
