WReckeR
thank you. I've only worked a little with heat shrink tubing. I assume you had the tubing over the wires before you began to solder. Obviously you can't put the tubing on once the lines are permanently connected.You only need to use the WHITE and BLUE leads to hook up the two lights. If you look closely at the pic below, I took the grounds from both lights and tied them together. Did the same for the +12V leads. I then took the WHITE lead from the CURT to the BLACK leads of the lights and the BLUE lead from the CURT to the RED leads of the lights and soldered them and then heat shrinked them individually. One individually heat shrinked, I then took a larger diameter heat tube and encased the two together. After all was buttoned up, I added split loom and self-sealing silicone wrap for a 100% water tight connection.
Never considered the Luyeds because I don't like them and they look cheap. I thought the beefier solution that @saylor did looked awesome and more befitting of a large 4X4 truck. Personal opinion, but the small lights just didn't do it for me. The wiring I did would also to apply to the Luyed light installation so no differences there.
Backup camera lighting has made it into my top 5 most essential mods.
