- Apr 11, 2019
1) The door harnesses you have listed are just the jumper harnesses that plug into the main door harness and the handle. Your current door harness does not have the connector needed for that jumper harness to plug into. You would need those jumper harnesses, and new door harnesses to make it work. Or...you can PM me, and let me build you a set of harnesses that you just integrate into your current door harnesses.Hi,
I am a longtime lurker and very thankful for all the research and efforts to resolve this problem. I was hoping that someone could verify the PNs needed for a 2019 RAM 2500 Bighorn in Bright White? I think I have pulled the correct PNs as it appears the HDs have a singular handle assembly with no separate cap? The PNs I get are:
68402181AB -Door Harnesses x2
1UJ81GW7A1 - Left Door Handle Assembly
1UJ86GW7A1 - Right Door Handle Assembly
68375990AC - Rear Bumper Receiver
I have AlphaOBD, the security link, and BT dongle as I am planning on adding TTPMS and Heated/Ventiliated seats. May also try to add rain sensing wipers.
Any information would be greatly appreciated.
Cory
2) Assuming the last digit in the part numbers for the door handles is supposed to be an I, not a 1, then those are the right handles for body color bright white without chrome.
3) There is no bumper receiver for the proximity handles. That part number is the receiver for TTPMS. You do need the antenna for behind the bumper, so the tailgate handle will work passively. The antenna part number you need is 56046957AA.
