Ram Limited Dash issue
Nautiknots
Has anyone yet experienced the leather from their dash lifting up! Currently have 50,000 miles on my truck and I don’t believe FCA will do anything about this issue. Has anyone ever attempted a repair without replacing it?
Neurobit
RAM Sorcerer
Texas
Some here have, not just on the dash but also on the top portion of the doors.
This is a defect and not normal. Take it to the dealer and have them put in a new one. Also check your doors so they can address them on the same visit if applicable.
Cheers,
Nautiknots
Cheers,
Thank you for the reply. I’m just concerned they won’t cover it due to the 50000 on the odometer
securityguy
North Florida
Unfortunately, it is very common. The ONLY fix is a new dash. The top cover cannot be replaced. I doubt RAM will cover it, based on your mileage, but it can't hurt to try. Once mine started to do the same, I traded her in on a 2021. Mine started in the same place as your pics, but mine was not as bad.
Malodave
Rindge NH
I would like to find a cover to put on the dash to protect the leather from the heat of the Sun.
Malodave
duke2001
As others have said, FCA probably won’t cover under warranty, but you should ask anyway. Then, if they refuse, take it to an auto upholstery shop and let them try to repair before you replace. They may be able to shrink it back in place, as it is leather.
securityguy
North Florida
Malodave
I don't believe that any one makes one. They are typically made for older trucks that had dash cracking issues way back when. If you do come across something, please do post.
xcarolina
Eastern NC
@grimreefer @davidn0021 Check out heatshieldstore.com. They make them custom cut, and I had them in my Jeeps and now in my 20' 1500. I attest to their performance and quality. Use the code FEEDBACK17 for 10% off.
Sent from my SM-N986U1 using Tapatalk
RamCares
Michigan
Hi there, we are terribly sorry to see that this is happening to your dashboard! Please send our team a private message for additional support alongside your dealer service. We would be more than willing to escalate a case on your behalf for additional support.
Kathryn
Ram Cares
Rsorrell2
Chula Vista CA
I had a 2014 Jeep Grand Cherokee and they had the same issues and FCA extended the warranty for that and had mine replaced even after the original warranty had expired.
I would think that FCA should do the same thing.
RamCares is this something that can be addressed? I mean if they did it for Jeep why not Ram? Same FCA.
j_volley_spike
Exact same issue is happening to my '19 Limited. Passenger side leather dash cover is coming up. I believe these leather pieces are glue on with adhesive. Did you get any success opening a case with Ram Cares?
titan3636
St Augustine FL
Just got into my 21 limited and mine just did the same thing! im at about about 20k miles. going to contact my dealership asap!
securityguy
North Florida
This just goes to show that FCA has done nothing to resolve the issue which is extremely disappointing. My 19 dash did this and royally ****** me off. The glue the vendor is using is the issue. It either doesn't go well with UV or heat. Regardless, you would think that, by now, someone would have learned their lesson and change the manufacturing process and/or the product. My next truck will either be a 2024 Chevy Silverado ZR2 or a GMC AT4X.
river rat
Houston
You may want to take a look at the chevy corvette forums, quite a few issues with their leather dash trim. I'd expect the new silverado leather dashes to experience similar challenges.
titan3636
St Augustine FL
good luck with either of those. GM has totally gone to the dogs. I was always a big chevy guy from my first Camaro back in the day.... my 2017 Silverado LTZ however was one headache after the other and had terrible shift/transmission issues that they refused to ever resolve. Broke my heart because chevy trucks were always the leader of the pack for me in style and quality for decades. In the last 10 years that has all gone to crap tho. I have many other friends with new and new(ish) GM full size trucks and suvs with all kinds of issues. At this point I have a much harder time finding someone that I know that is happy about their chrvy/gmc purchase than people that regret it. plus they don't look near as mean as RAM inside or out. to each their own tho, just my .02
