I will. The seller said he presets these for leveling.
Did you let him know you have a Limited? I believe the seller has a Rebel which has longer stock links.
In any event, the links you receive should be a little shorter than your stock links. If they are longer, do not install them.
Man please keep me posted on your finding.I ordered parts to make my own adjustable level links. Gonna play with it a little.
I sure did, and don't know what he drives. I don't think that video is his.
Have you tried the DIY links yet. I bought all the parts I just have not tried yet.I haven't assembled this yet, but if anyone wants to do it as well here are the parts:
Parts list for DIY leveling links (front)
4 each ($7.50 each) of Bansbach 8mm ball socket 22mm M5 thread
1 each ($2.42 each) of Fabory M5-0.80x1M threaded rod (you will need to cut this down to size)
4 each M5-0.80 nuts
Here are the parts I ordered from Grainger. Also need M5-0.80 nuts (easy to find at auto parts store or hardware store).
Bansbach 8mm Ball Socket 22mm M5 Thread
https://www.grainger.com/product/6U...58522c9f1624d4796e6fec12e8dc31a71445c63245414
Fabory M5-0.80x1m, Threaded Rod, Stainless Steel, A4, Plain
https://www.grainger.com/product/25...58522c9f1624d4796e6fec12e8dc31a71445c63245414
What the lines have to do with leveling by the links.Not yet. Still doing research. What I really want is to add a 2” spacer, Mopar uca and the links to retain factory ride and full air ride functionality. My concern is with the air ride supply lines.
They need to be disconnected in order to install spacer and uca. I don't want to just do the links mod by itself.[/.
Have you seen that AEV includes extensions in their kits for the 4th gen? Maybe they can sell you an extension kit or maybe some one like these can help http://www.rebuildmastertech.com/
Now I understandThey need to be disconnected in order to install spacer and uca. I don't want to just do the links mod by itself.
I see and I understand you’re breaking ground with no support. Wish my truck was in so we could exchange info on a different level. How about this though: if you look at this installation manual from AEV you see that they’re using a bracket to extend the link you want to replace. Perhaps some one on a Ram forum has this and can tell you the lengt they are in order to accommodate a 4” and then calculate from that? https://www.aev-conversions.com/wp-content/uploads/2018/06/AEV30308AA_1500_Air_Ride.pdf@Pnorth
The only thing is I don't know how much to adjust the links by. It is all trial and error. Once that is figured out, then a bracket would work great for the final product. Man, I wish one of these companies would do it but I understand why they don't lol.
Here's a place to start. Adjustableairride.com sells premade links for $199. They have downloadable instructions and the ones for the 2018 1500 state that 5mm front adjustment equals .75-1" in ride height. Also, the front links should be shortened to raise ride height while the rear should be shortened.
Have not tried any of this but should give you a rough guide.
Problem is 4th gen stock links are longer than 2019. That's why they are taking so long to come out with a 2019 kit. So I think the math is also different. It probably needs trial and error adjustments. The other complication is the air ride on rebels and trucks with the off road package have different air struts and compressors for the extra 1" lift. So complicated lol!
Yep, you called it. The guy I bought from sent the links but they are longer. He is trying to get a Limited to measure, and I losing my patience with him because he told me Sunday he would be at the dealer Monday. I ordered them on the 22nd
