Great info! Do you know if there is a unit available for resonable money that can program something like this - making it possible to test this out?
Yes, that is probably the most important question - would they be willing - and at the same time - I would be willing to try myself and why I was thinking if there is a computer program and a cable, for instance, like I have for BMW or Audi, that lets you program settings etc.I'm not aware of any, but it definitely can be done by the dealer. The question is would they be willing to do it.
I ordered parts to make my own adjustable level links. Gonna play with it a little.
I be interested in making a kit also,lets us know how it goes.
I couldn’t bring myself to spend a couple hundred bucks on revel’s leveling links when it looks so easy to make/piece together. I’m curious how it goes for you. I might do the same. Thanks!Revel confirmed that 2019's use 8mm on both ends and that they need to correct their install instructions. Picked up additional 8mm ball links from Grainger today.
I wouldn’t want to open up the factory air system. It’s essentially the same process as an air conditioning system. It is profiled and charged with nitrogen. It doesn’t pull in outside air. The compressor is to move air from one place to another.
If you open it up you’ll be introducing moisture and inconsistency in ride quality and height consistency. They pull a vacuum. Pretty amazing system.
Anyways just wanted to say don’t suggest opening the system as it’s a closed style system
Has anyone commented on these?
https://www.linksforram.com/
I ordered a set but haven't gotten them. Just interested in leveling a bit.
Let us know how it works out. Would be curious to understand how the threaded rod stays in place without moving in the socket ends. The older generation stock links are longer than the 2019 links so hopefully there is guidance in the instructions on what length you need.
