Key Fobs and LED interference
GB1911
Mass
My cargo lights stay on even after closing the door. I don’t have bed lights either. Out of curiosity, when you open the tailgate do your cargo lights come on? I enabled it with AlfaOBD since the factory doesn’t, maybe that’s why they stay on. But I had no issues with my ‘20 which was set up the same.
They come on with the tailgate open and will stay on unless I go into the truck and turn them off. They also come on when I unlock it
z0n3
Anyone with a 2021 Laramie using diode dynamics without issues??
MayhemMOORE
I’m stuck between ordering a set to try, or just ordering the factory led light and being able to add the mirror later on if I want.
trithumb
Have you been able to find the mirror? I looked a couple times and came up short
MayhemMOORE
I haven't really looked for it yet. I figure I can source the light and then add the mirror later on as availability increases.
trithumb
375 for an led light isn't interesting enough for me to spend that. Depending on the mirror cost I'm down for adding that in if I can get everything for less than 1000
Jimmy07
Honorary Site Supporter
You can get them both for under $1000.
Digital rear view mirror- 68448641AB
CHMSL with camera- 68444540AB
z0n3
I sent them a message asking if they have heard of any issues specifically with 2021 Laramies. I can’t quite justify $500 for the LED cargo light yet.
kdoublep
USA
2020 big horn level 2. Do not have passive entry. Lasfit cargo lights only. Stock 3rd brake light. No problems. Had them for about 3 months. They come on when I unlock doors with fob. (Looking for some wood to knock on).
z0n3
I received a response from diode. They told me they have not heard of any types of issues with 2021 laramies with their 3rd brake or cargo light bulbs.
z0n3
I went ahead and ordered a pair of the cargo lights and a 3rd brake light from Diode. Ill report back when they're installed. Might be a while as they're shipping USPS 😕
MayhemMOORE
You'll probably see them sometime in March. Standing by to see if they work out for you. Did you go with the cheaper ones or the $90 ones?
iLikeTurtles
Is there a stocking issue? It’s been awhile but two months ago when I ordered them they came in a week.
z0n3
I just did the cheaper ones. $45 for the 3rd brake light and $40 for the cargo light pair.
glasswagon
USPS is so backed up right now due to the holiday shipping rush, it's ridiculous and people want more government run things...
Shuga
NY
What's the cheapest option for a 20 Laramie? I just want the cargo lights not the 3rd brake light.
z0n3
By some miracle I got the diode dynamics bulbs in today via USPS. I put them in and put the truck away. So far no issues. Used to have an issue with lasfit bulbs if my fob was in my pocket but no issue doing that with the diodes. I’ll update after this week.
MayhemMOORE
Great news, thanks for the update. I’ve had no issues with the lasfit brake light, just the cargos. Wondering if I should just order them all from dd to avoid any future issues.
