westcoastram
Those that are running the 6" w/ 37.s What gears are you running and are you still able to tow? I'm going to be adding a Zone 6" IFS. I have the 3.92 gears and have 35's on order. Trying to decide if I want to go up to 37's but don't want to compromise much more towing capabilities
scRAMbled
Thanks for the tips! So basically you excluded the preload spacer. Since you excluded that did you see a true 2” lift that readylift says you should see. Also did you put the rear spacer on? It doesn’t look like you have much rake, truck looks great!! I starting to lean more towards a motofab 2.5 and 1.5 rear spacer which would leave me with about an inch rake.
Here's my truck...2.5" front, 2" rear. Started with Readylift SST but swapped all the front spacers for a Motofab 2.5" top hat. Rides very smooth. Tires are 305/55/20s with a 3/8" spacer. Don't necessarily need the spacer but I wanted to make sure I had room. I have 1"-1.25" of rake depending on where it's parked. Needed some rake for towing and hauling.
Pyleketerson
Well done! I really like the stance. Looks great!
Jason2020
I have the 3.92s, but also the ecodiesel. Towing a 6k pound camper through Colorado really wasn't an issue. I got about 14mpg with the camper and still getting 22 mpg-ish empty on the highway according to the dash.
targetpanic
I have a 2020 Quad Cab BTS (includes 1” ORP lift). Will be keeping stock 20x9 rims. Does anyone have a picture of this truck with a 2” front and 1” rear lift? Or 2.5” front and 1” rear. I’m thinking Rough County UCA, Motofab 2” front top spacers and 1” rear spacer
CJR28
Second this post, 2020 BTS crew, planning on keeping stock wheels and doing Bilstein 5100s on #5 in the front with 5160s in the rear with a “1 spacer also with RC UCAs. Anyone have a similar setup with pics? Thanks
5thGenRebel_AMK
PA
Bilstein 5100's on level 5, 35x12.5R18 Nitto Exo Grapplers, and Fuel Shok's 18x8 -12 offset. Had to bend the metal bracket behind the plastic mud flap, also trimmed off the portion of the mud flap that rubbed so i could keep those pieces on. Drives/rides like stock
SzymiRam@2019
That looks nice. I was going to use those same rims with my 35x11.50 Nitto Ridge Grapplers, but have decided on the Fuel Beast 20x10, -18 offset for my wheels. My width will be very similar to yours, just a touch more wider. Don't want the 12.50 width over an inch outside my wheel wells. Thanks for sharing.
Hey, do you have any pics of your wheel and tire setup? Looking at getting the same rims, but would like to see some pics before I pull the trigger. Thanks.
2Fast-4U
Here is a picture that i got from the Custom Offsets gallery of the wheel & tire combo. I have seen the wheels in person at the place doing my lift and they look great. I am hoping that my lift is in next week so I can drop the truck off next Sunday to get it back on Tuesday. Getting closer I hope!
SNAFU88
DaveR
I shopped for two months this past spring and never saw this color. Best looking truck I've seen on this site. Love it.
Thank you so much!! I had to search quite a bit for it- was the only one within 500 miles of me in that color (Olive green pearlcoat) and that had the Off Road Group. It came with the chrome plated wheels, which I just posted for sale as I now have the black Level 8 Hauler wheels you see in the pics. I don’t know why, but I just really like the green color... just something different. Appreciate the compliments! :)
Dave
DaveR
SNAFU88
Love it. I literally did not know this color existed. Didn't see a single truck like this in my search. I just checked Autotrader for fun and there's about 110 green Laramies nationwide, and none within a 300 mile radius of where I live. Strange that dealers around here don't order that color.
Bufo
do you have more pics??? Looks great
I don’t take many pictures but I did wash it today. First time in a while! It goes down a lot of dirt roads to the fishing spots so it’s always dusty. I don’t normally drive around with the mirrors up, just flipped them up to wash under them.
Bcryan
2019 Bighorn with Readylift leveling kit and 275/65/R20 Nitto Ridge Grapplers. So happy with the results!!
From what I have read and from past experience this is the way to go... I’m guessing this kit came with the new a-arms?
