turkeybird56
FWIW, I just picked up the September 2020 issue of Consumer Reports Used Car Buying Guide (ISSN 1530-3267) and in the rating for 2019 Ram 1500, under category Climate System, the Ram has a Dark Green* symbol, meaning "much better than average."
*Models that score a DARK RED DOT are not necessarily unreliable, but suffer a higher rate of problems than the average model. Similarly, models that score a DARK GREEN DOT are not necessarily problem-free, but had relatively few problems compare to other models. Because problem rates in some trouble spots are very low, we do not assign a DARK RED DOT or an ORANGE DOT unless the model's problem rate exceeds 3 percent. If a problem rate is below 2 or 1 percent, it will be assigned a LIGHT GREEN or a DARK GREEN DOT respectively.
Climate system problems reported to CR appear to be 1% or less of the reporting population for 2019 Ram (DT) 1500.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 17 July 2018. Now at: 036282 miles.
Me thinks they have not rode in any 2019 dt's LOL
