busa2009
Does anyone know where a ignition fuse would be in the engine bay box im hooking up the DRL i know the black to ground red to battery and grey to ignition...just trying to figure out where a ignition spot would be
Short Answer: F60
When I ordered the AlphaRex PRO-Series Headlights, I noticed that they did not have any installation instructions posted on there website. So I contacted the Tech Support at AlphaRex. They told me to use the F66 fuse. Which is valid for the 4thGenRams but not the 5thGenRams. After he told me that he did not know which fuse to tap, he said that I could wire it to any 10 Amp - 20 Amp fuse that would come on with the starter.
When I saw that the fuse that was on the pigtail for the DRL's was a 15 AMP fuse I went with a 15-20 Amp fuse. I tested the fuse box with my Multi-Meter to figure out which one I could use that would only turn on when the truck was running. Most of the fuses had power all of the time. The only one that I could find was a F60 Fuse : ECM / PCM / ACT Short Running Valve.
Since this is a critical fuse I decided to use a fuse tap so that the tap was clean.
Our trucks use the Micro 2 Fuse
You can pick one up here: https://smile.amazon.com/gp/product/B01LFXA5YQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Here are some pics of the install:
This was after using the remote start prior to unlocking the truck. I leave the dial in the “Auto” position and once I unlock it then the headlights illuminate
no because they are H7 your fogs are H11Would you happen to know if I could take the halogen bulbs that came with the AlphaRex headlights and put them in my fog lights?
The DRL's will come on at 50% power when the headlights are on. (without wiring the DRL's)Im curious if you have the light set to auto then they work as normal Im trying to figure out why I should hook up the wiring harness.. My DRL are working just fine with setting in the dash turned on
The fuse taps came with 5 amp fuses. The fuse I’ve tapped is a 10amp. Does it have to match the original, or can I use the 5 amp fuse the tap came with? Sorry, don’t know much about electrical. ThanksYes, You have to pull the factory fuse and put it in the load side of the fuse tap then put the fuse for the headlights DRL in the second slot.
If you look at the pigtail you will see that it came with a 15 AMP in-line fuse. (This tells you that it requires 15 amps to work properly)One side seems brighter the driver low beam/daylight
I'm not sure that I understand your question LED turned in the housing. Are you talking about replacing the halogen bulbs with LED.Mine is working normal as expected. Awesome. I may have to adjust them here and there though. My question is does it really matter as to how the led are turned in the housing?
No the AlphaRex are H7 and your fogs I believe are H11. I put the MoriMoto fog lights in and couldn’t be happier with the color and cut off on them. World of difference driving at night now
Where is the best place to order the H11.? I would like to try them,sounds awesome. Can I run led in my fog lights?
				Take the filter air box out and you have room to adjust the passenger light.What’s the trick to adjusting the passenger headlamp....not sure how to get a wrench or screwdriver in there. My light is way too low.
Thanks I’ll try thatTake the filter air box out and you have room to adjust the passenger light.
