Interior Rattles
RamCares
Michigan
Mark- I appreciate you sentiment but the words ring hollow. I have an active case that has gotten no resolution after mutiple trips to the dealer. Case #68212567. I look forward to you escalating this issue and getting it resolved. Thanks.
Alex
Hey Alex,
Thank you for following up. I sincerely apologize for the frustration associated with your situation. After looking into your case, I do see that your case manager is awaiting a return phone call from your dealer so that he may follow up with you regarding next steps. Please reach back out to our team if you do not hear from your case manager by Friday.
Mark
RamCares
illucid
Maple Ridge BC
Hi illucid & alramguy,
Your sentiments expressed here are completely understandable. We are more than happy to escalate cases on your behalf if you address this with your dealers again. This will allow us to have your concerns formally documented, as well as to ensure that all potential solutions are explored regarding the rattle that you are experiencing. Our team is just a PM away.
Mark
RamCares
But I'm in Canada and I dont believe you can actually help me...
RamCares
Michigan
Hi illucid,
I do apologize for not catching that. If you continue to work with your dealer to address this, we suggest contacting Canadian Customer Care to have this documented. You may find their contact information by clicking on the following link and scrolling down to the "Canada" tab: https://www.fcagroup.com/en-US/footer/Pages/contacts.aspx.
Mark
RamCares
TAMUG01
Your issue sounds very similar to mine. I popped the vent out with some dash tools. It was very easy. The rattle seems to be coming from where the instrument cluster and dash meet right near the left drivers vent. I think the cluster or dash is going to have to come out. I have an appointment Thursday with the dealer. I am not optimistic because they don't seem very motivated to help solve the issue. I have opened a case with Chrysler/Fiat but so far they haven't provided any resources. Let me know if you make any headway.
Did you ever get a resolution from your dealer? I removed the cluster ring like KRField described and showed in his photo but that didn't solve my rattle/buzz.... :cry:
I suppose I can remove more of the panels to narrow it down but gd....
KRField
Tri-Cities, TN
I found another source for interior rattle that sounds like it’s in the dash. The cover plate behind the door handle. Trying to figure out how to silence it.
JDGRam19
NC
I’m having the same trouble!! There‘a a click/rattle behind my USB ports on the wireless charger.
QUOTE="RamCares, post: 190782, member: 183"]
I'm very sorry to hear of the concern you are experiencing with your truck. I certainly understand why this would be frustrating! If you do not receive any advice here and you decide to address this with your dealer, please feel free to send us a private message. We'd be happy to have this documented and provide you with an additional layer of assistance while you work with your dealer.
Mark
Ram Social Care Specialist
[/QUOTE]
RamCares
Michigan
Mark
[/QUOTE]
Hi JDGRam19,
I am very sorry to hear of the trouble you are experiencing. To clarify, have you had a chance to address this with your dealer? If not, we kindly recommend doing so as they are in the best position to assist. If you do work with your dealer, our team is just a PM away and we are happy to support you through that process.
Mark
RamCares
HR45th
I think I may have found the rattle behind the rear seat in mine. I think it is coming from the cab vent between the cab and bed. When you shut the passenger rear door and look down between the bed and cab you can see the vent open and close. This may be the source but I have no way to access it myself. Going to have the dealer look at it when I go in.
retho78
Same here, I took mine in for the door rattle and they said it is coming from the cab vents and it's normal.
RamCares
Michigan
Hi HR45th,
If you would be interested in an additional layer of support for your dealer visit, please do not hesitate to follow up with us via private message!
Mark
RamCares
2020SilverMidnight
I have a rattle that sounds like its coming from the front passenger door or the pillar between the passenger front and rear doors. Most of the time I am alone driving, so its kind of hard to diagnose. It drives me insane! If anyone has found the source of a rattle in this area I sure would like to know what it was.
I have this exact same rattle now. It started this morning on the way to work. Did you ever narrow it down or find a fix for it? Thanks for any help you can provide!
RamCares
Michigan
I regret to hear that you are experiencing this, 2020SilverMidnight. If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your dealer, please know that we are a private message away and happy to provide further support.
Mark
RamCares
2020SilverMidnight
Mark
RamCares
Thanks RamCares! I appreciate that! I actually found the source of my rattle this morning.
RamCares
Michigan
Thanks for following up to share, I'm glad to hear this! If you are ever in need of any support we are happy to help.
Mark
RamCares
LogJammin
Did you ever confirm the source of the rattle...was it the cab vents? I have a rattle that comes from the back, really gets going around 50+ mph. Thought it was my Leer Canopy, but I've pretty much eliminated that. I've already looked behind the seats and taped down the LF modulator that was loose...this rattle is driving me nuts!
Tool man
I took mine back to the dealer...they took dash and console apart and put foam tape in necessary areas.... NO MORE NOISES!!!!
I'm new to this site so please be patient with me (not sure how to start a thread). I purchased a new 2019 1500 classic about two months ago. It was solid until 1000 miles on the odometer( has 1600 now). Started getting rattles in the dash around radio when on roads with "imperfections" Now the passenger door panel rattles when I hit a bump. I'm reading where others are having rattle issues so I don't feel alone. I have a Hyundai accent with 141,000 miles on it and it is more solid then the ram. Any suggestions would help
Joeyp
Jersey Shore
Welcome to the world of the fifth generation ram!
RamCares
Michigan
Hi @Tool man - Thank you for taking the time to post here, I regret to hear of the trouble that you are experiencing with your truck! Please know that if you decide to address your rattle concerns with your Ram dealer, we are more than happy to connect you with a specialist who can work alongside you and your dealer to try and remedy your concerns as soon as possible. Our team is always a private message away to get the process started. If you hover your mouse over our profile icon, you should see the option to 'Start Conversation'.
Mark
RamCares
