Mpickwith
 - Mar 7, 2020
Reverse connectors to the LEDs... They are polarity sensitive
Thanks swap the wires in this connector?
	Not sure which one that is in the picture but you need to swap the connector that goes directly to the LED bulb since they might not be turning on due to reverse polarityThanks swap the wires in this connector?![]()
In my truck F37 is 5A - F38 is 10A...everyone says F38 but in the video he clearly is pulling F37...
	Sorry to hear about your issues. What exactly is happening?Looks like my Aukee H7 LED are not playing nice with the CANBUS system of the truck...anyone have similar experience? It is weird since i was running the same model Aukee but H11's with the stock housing.
I went with F66 under the dash. It’s an “accessory” fuse so you won’t be pulling a load from something more important. No more issues.
Looking great. By the way, do you need to get a converter with the led Morimoto Fogs?![]()
Not as bad as anticipated but the first time pulling that fascia is nerve wracking. Broke one of the clips the first time but the second piece coming off was much easier. Total time with a 1 year old and trying to figure out why the highs/lows wouldn’t work was a little over 2 hours. Definitely would be much less the next time. MoriMoto fogs will be here Monday as will my RC grille lights but now debating the grille lights
When I ordered the AlphaRex PRO-Series Headlights, I noticed that they did not have any installation instructions posted on there website. So I contacted the Tech Support at AlphaRex. They told me to use the F66 fuse. Which is valid for the 4thGenRams but not the 5thGenRams. After he told me that he did not know which fuse to tap, he said that I could wire it to any 10 Amp - 20 Amp fuse that would come on with the starter.F66 is being used by my dash cam
F66 is a valid fuse, it’s under the steering wheel but it’s not a fuse to a major component like how F60 is. F66 is for “Accessories” like the DRLs.When I ordered the AlphaRex PRO-Series Headlights, I noticed that they did not have any installation instructions posted on there website. So I contacted the Tech Support at AlphaRex. They told me to use the F66 fuse. Which is valid for the 4thGenRams but not the 5thGenRams. After he told me that he did not know which fuse to tap, he said that I could wire it to any 10 Amp - 20 Amp fuse that would come on with the starter.
When I saw that the fuse that was on the pigtail for the DRL's was a 15 AMP fuse I went with a 15-20 Amp fuse. I tested the fuse box with my Multi-Meter to figure out which one I could use that would only turn on when the truck was running. Most of the fuses had power all of the time. The only one that I could find was a F60 Fuse : ECM / PCM / ACT Short Running Valve.
Since this is a critical fuse I decided to use a fuse tap so that the tap was clean.
Our trucks use the Micro 2 Fuse
You can pick one up here: https://smile.amazon.com/gp/product/B01LFXA5YQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Here are some pics of the install:
I wonder if you can add another tap. I’m wondering in case I need to install anything else in the future.F66 is being used by my dash cam
I did not want to go through the firewall for this installation ,wanted to keep all of the wires in the engine bay.F66 is a valid fuse, it’s under the steering wheel but it’s not a fuse to a major component like how F60 is. F66 is for “Accessories” like the DRLs.
	No instructions for the wiring with mine either. Once you stretch it out, it's pretty easy. One lead to the lower white wire on each light, the red and black to battery and the grey to your fuse tap. As a note, if you plan to go with LED's, I suggest you do that before installing the lights. Much easier and if you drop the LED inside the housing, most likely you will have to remove the light again to fish it out, ask me how I know that. LOLMine just got in. Let you know how it goes hopefully install them Sunday I didn’t get any instructions on the wiring though.![]()
