LYDIA:
My entire rear passenger side window spontaneously shattered while driving and FCA is refusing to warranty repair it. Can you assist me in som eway? I believe these hairline cracks were on my window as well which resulted in a weakening that left it susceptible to failure. THANKS!
Got mine back at midday today. What is interesting is that the window is now better centered than the original. The original had an ⅛" gap on the pax side and about a 1/4" gap on the driver side. With the replacement the gaps on both sides are identical. I wonder if the failures were due to windows not being installed squarely, creating enough stress to crack them. With the replacement when I looked between the gap between glass and body, I notice a healthy bead of sealant that was semi-firm. Perhaps this thicker bead will provide a bit more flex to the window frame especially when we go through temperature extremes. Maybe this will allow a bit more expansion and contraction and reduce the risks of cracks. The dealer (Ziegler Dodge/Ram in Grandville, Michigan and Chad (Service Manager)) was outstanding.Keep us posted. I have your recommended parts on order to address.
I just tried to duplicate/pinpoint my leak using a tea kettle full of water, which worked last time pouring it all over the brake light and rear window.
However, I cannot duplicate this one. Not sure what's going on here.
There is a big rainstorm coming tomorrow so I'll go out and see if it's coming in again.
Im am battling FCA regarding what seems to be a catastrophic consequence of having these cracks: the entire rear passanger window shattered while driving last week and FCA says its not able to be warranty repaired because "an outside force acted upon it" Trucks are designed to be driven right? How would outside forces not act upon the tires and travel up though the suspension and frame? Would anyone who had these cracks or a blowout of their window be able to help me by providing the last 8 of their VINs? FCA is debying that they have repaired any 2019Rams for this issue but clearly this thread proves otherise
Why has Ram not addressed this? It’s the same window and they will leak again. Some are on at least their third window. Mind blowing
That was my post. Glad it worked for you! Mine has been leak free even with very heavy rains lately.I saw someone else posted this fix for the third brake light leaking and it also fixed my water leak. Removed the original crappy seal and replaced with this..
Great to know! Thank you for the post, I really didn't want my back window replaced if it didn't need to be.That was my post. Glad it worked for you! Mine has been leak free even with very heavy rains lately.
That is the first real explanation I have heard regarding the cracked windows. Has the two diff vendors been the case for a while or just recently? ThanksThe issue is the two different vendors that supply the rear window, they may or may not have an actual fix for this. These vendors also supply GM, and if you check out the Silverado / Sierra forums, they have an even larger thread covering leaking rear windows.
The vendors hopefully have figured this out, because you got a lot of trucks with potentially expensive repairs.
Well, after 22 months in service I finally have a leak at the back of the cab. The technician performed the diagnostic procedure found in the STAR case I've included. (This Star case was issued on the day I took it in.) After performing the procedure he determined the leak was at the top of the rear window. The window frame IS NOT cracked nor showing any signs of fracture lines. The headliner was wet all along the rear portion where it contacts the top of the window frame, not just the corners.
They had already replaced the CHMSL assembly that includes a new urethane gasket soon after I purchased the truck. The original one had an black, open cell foam gasket. The tech. determined that it was not the source of the leak, nor the shark antenna.
Based on comment from the tech., engineering has found many of these leaks being caused by the urethane sealant that was used. Apparently they've found bubbles in the hardened sealant that eventually produces a loss of seal.
My dealer has a glass shop do all their glass work. Now I'm waiting for a window.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 17 July 2018. Now at: 032192 miles.
What did you used to seal them together( end to end)?This was my fix.
	I did the same fix and I didn't use anything to seal the end but made sure not to leave a gap. I suggest having the start and stop point at the bottom of the light assembly not the top. If you are concerned about it then I suppose you could put a bead of super glue across the seam. It works, I ran water over my rear window ( just to make sure it wasn't the window leaking) and third brake light assembly for a good 15 minutes and no water leak.What did you used to seal them together( end to end)?![]()
Nothing. I made sure the seam fits together tight and is at the bottom of the light. Zero issues.What did you used to seal them together( end to end)?![]()
Third brake light replaced last week, and 17 months after driving the truck off the lot, the truck is leak free. So now I am wondering if it wasn't the third brake light leaking all along, and the crack in the rear window frame just provided a channel for the water to run in easier.I had the crack in the rear window frame. Had the rear window replaced and it still leaks, but not as bad. I removed the third brake light assembly last week and the bottom of the gasket was saturated. I could squeeze water out of it. Did you find a similar condition when you removed your third brake light assembly?
Can you help me as my rear window shattered and FCA denied warranty replacement. I need to collect some VINs or at least the last 8 digits to illustrate that Ram is replacing a good number of these faulty rear window but denied mine. The cost to me is $1900+ and my policy isnt covering broken glassGot all of it taken care of, will see how the new rear window doing.![]()
Not to state the obvious but a shattered window is a little different than a leaking window due to a manufacturer defect. I hope it works out for you but it's going to be hard to get FCA to replace a shattered window under warranty unless you can prove without a doubt that it shattered due to the defective frame. Maybe try working through your auto insurance to see if they can help. How did it shatter?Can you help me as my rear window shattered and FCA denied warranty replacement. I need to collect some VINs or at least the last 8 digits to illustrate that Ram is replacing a good number of these faulty rear window but denied mine. The cost to me is $1900+ and my policy isnt covering broken glass
I would def start with the brake light. Mine was dripping from the headliner area and I also do not have cracks. Replacing the seal on the brake light fixed mine.It's raining and just saw a drip from the rear passenger side at the edge of the headliner. No cracks on the rear window yet. Wonder if it's the brake light even if it's at the passenger corner?
