Limited built 7/8. After tree weeks driver seat (frost) shows significant wear line along outboard edge, like the leather disintegrating . The right side of the dash was off from the pillar by an inch and stuffed with a square piece of foam that stuck out to close hole. Turns out they didn't get the pillar trim piece in the dash clip to secure it so they stuffed a piece of rubber in the gap. Used trim removal tools and installed correctly myself minus the filler. Doors all need alignment especially r/r door , looks open also has a small dent at bottom corner, will request dealer fix at first 1000 mile oil change. Went to lift rear mat to clean, all the mat fasteners came out with it. turns out they put the retainers in upside down, you have to lift the carpet out to fix this, real pain. Somehow the gap above the rear window (left side) and the roof got overspray in it from the spray liner , they cant get it out , just had them give me touch up to cover it , you really cant hardly see it. They definitely have to up there quality control , My 15 was flawless. Mechanically all is great , still impressed with the ride and hoping for uconnect update, it has a mind of its own every time you start.
