TAZER DT for 2019 RAM 1500
Had one on my challenger never run into any issue.
Almost trouble free 8000 miles on Ram
Been pondering this but too many people having issues.
Curious. Is anyone not having problems with this product?
I'm not any longer and use quite a few of the features. -- remember, this particular device "replaces" the Security Module underneath the driver side dash, so it may take a time or two to get it going. I'm sure the Techies will get a better update for it.
Only issue I have is some times the Tazer will not go to sleep mode and if the truck is not driven for a couple of days when it does you find a dead battery when you try and take of. ): Very annoying! The one on the Scat Pack Charger is two years old and no issues what so ever! (:
No issues aside from the manual sucking, and some "advertised features" not working as advertised.
Figured it out for the most part - it does what I wanted it to do. Looking forward to them adding more features to it, if the device has enough memory to accommodate.
Rick
How do I use this to disable the lights when I unlock or open the door?
I've had the Tazer DT for about two months. Overall, I am glad I purchased but have had some issues which were communicated to Z Automotive. Firstly, I do not know if this has anything to do with the Tazer DT but I have received an error code of "Service Stability Control" every 15 or so startup. After turning off the truck and restarting it shows no errors and retains no codes. Next time I am at the dealer I will have them look at it, but coincidental or not this started about the time I installed the Tazer DT. Secondly, I had the turn on back camera with turn signals option. This made using CarPlay almost unusable as every time the turn signals were turned on and subsequently off, it would "turn-off" CarPlay. This was communicated to Z Automotive and they identified as a known issue. They had not heard or witnessed the error code described above. Other than this,I have been satisfied.
Which lights? Headlights? that is in your owner's manual .. don't need the DT Taser for that.
Park lights still flash for me, but I like that setting myself.
That can be controlled from u connect settings
Tazer have dark mode that will turn of every single light including interior and dash.
Anyone who wants to sell a tazer?
If you buy used do you get the same support? Do you need to have it reprogrammed by Tazer?
As long as it unmarried from previous truck before taking off. It is good as new.
