ChadT
- Oct 20, 2018
Yes, Classic is the older design with the curved door bottom. I don't know if there is any steel inside them but you only have to open one to realize that the DS (older design) is far heavier than the new DT redesign. That alone explains why the warping is happening.
Hmm, the look mechanism is pretty different too.
A friend of mine has a Gen4 rebel, got one around the same time I did. His has an issue with the lock not working. Won't turn or something to that effect? Er, doesn't work with the fob, he has to use a key, and it gets stuck?
Ram likely redesigned the Gen2 boxes to avoid that, to make it lighter (to eat into the payload less, the Gen4 trucks were not payload kings), and I assume cost to produce savings - that's what businesses do.
