Patsy1099
 - Jan 5, 2019
- Location
 - People’s Republic of New Jersey
Still confused on this phase stuff. I have a 6 speaker with ANC. (Also E-torque if that makes a difference.) I just want better sound by upgrading speakers. Looking at the JL 3.5's mentioned predominantly, with bass blockers. Back to the phase, I should I install the new speakers phased the same as the ones being removed? Or make sure all are installed in phase? I would prefer to retain the ANC. Also, understanding the ohm difference in the factory vs aftermarket 3.5's, what are the suggestions for the door speakers, front and rear.
I installed all my speakers in phase. Others have matched phase to what was installed. No matter which you choose it won’t matter for the 3.5’s. ANC only comes into play when you swap the doors. Then you best bet is probably to match the phase of stock. I knew I was adding an amp and a sub and therefore deleting the ANC so I put everything in phase from the start.
