ORG, Ready Lift UCAs, 2.5” Motofab spacers in front, 1” spacer in back, 35x12.5R20 Ironman All Country M/T, Fuel Warrior 20x10 -18 offsetView attachment 32621
Nice. You essentially have equal to the readylift 3.5 SST since you have the ORG.
Correct. Which is what I was going for. But to be honest, I may be regretting doing the 1” in the back. But I just did it today, so we’ll see how I feel about it in a week or so. I definitely have a little rubbing up front though, so I’m gonna have to get out there tomorrow and massage some wheel-well liners.
What don't you like about the 1 inch in the back?
They’re Ironman All Country M/Ts and they are knobby AF! But based on what I saw on the forums, I expected some rubbing. I got it 90% fixed today though. Just have a little bit of rubbing in reverse at full lock. Gonna fix it the rest of the way tomorrow.What tires are you running that would cause rubbing when you have 3.5” of Lift up there?
I don’t have the measurements after putting on the new tires/wheels yet, but I was just over 39.5” in front and 40.75” in the back with the stock ones. I didn’t get a full 2.5” of lift up front, but it was pretty close. And I definitely paid a heck of a lot less than they want for the full Readylift kit, which would’ve been useless for me anyway since I have the ORG.It does not look like 3.5" of lift based on space between tire and wheel well. What is your measurement from ground to center of wheel well? I'm at 42" from ground to center and 8.25" between top of tire and middle of wheel well. I have 3.5" Readylift on 35" Nittos's
Looks like a direct competitor to Ready Lift's kit or a knock off with shocks.Hello everyone! Tell someone newbie who installed this kit? Or advise another!?
Tuff Country 33506KN | 2019-2024 Dodge Ram 1500 4X4 - 3.5" Uni-Ball Lift Kit (new body style only) (SX8000 Shocks)
This Tuff Country 3.5www.suspensionconnection.com
Just got finished with a level and new tires. 2.5" front 2.0" rear moto fab level. 35" Ironman tires on my stock 22's. Extremely minor rub in reverse at full lock in one direction. Very easy to trim if I decide to. Could not be happier with the setup. Thanks to all on this forum for your experiences and advice.View attachment 33114
I'll add more pictures later - including the small trim that I plan to do. Standard coil springs / no air, yes front 2.5 and rear 2.0, and the tires are 35x12.5xR22.Can you post more pictures and tell us again the setup? Do you have standard coil springs, no air suspension or ORP? You lifted the front 2.5” and the rear 2”? Are the tires 35x12.50xR22?
That’s beautiful! How’s the ride quality?I'll add more pictures later - including the small trim that I plan to do. Standard coil springs / no air, yes front 2.5 and rear 2.0, and the tires are 35x12.5xR22.
I did this with my Tundra and it rode too ROUGH for me. Would need to talk to someone first, before pulling the trigger on it.The best way to level the 4th gens is with the Bilstein adjustable front struts. I imagine that will continue with the 5th Gens as well, they are adjustable from stock height up to 2.8 inches of lift all whole improving ride quality over the stock struts.
Thanks! Yes, very happy with the result. Ride quality is fine - only change is what is typical with MTs, some road noise but not too much. Otherwise the ride feels similar. My own two cents on this - thinking this is as much of a lift that I would do for the truck - feels just right. Finally putting the auto running boards to work - access is easy - any higher might impact cornering, and it fits like a glove in my garage (2 inches of clearance).That’s beautiful! How’s the ride quality?
