Great work. They look great.Liners came in today and installed it.
Pictures attached.
Pictures attached.
Thank you.Great work. They look great.
Thank you.Significant change... nicely done!!
Yep, sorry for the mistake, 8. I forgot I had bought 2 already...I also have a BigHorn and just ordered the liners and 6 screws.
However, after watching the video again, I realized that if I follow all the steps I actually need 8 screws, correct?
For each side you need 3 for the wheel arches, and 1 for the inboard hole in the back of each wheel well.
Let me know if you have any other questions. It was an easy install. Hardest part was lining up the holes
I will try to find my packaging tomorrow in the garage and will update as soon as I canI installed my liners tonight. However, I apparently ordered the wrong screws, so I’m still 8 short. I have an appt at the dealer tomorrow for the v61 recall. Can you, or anyone, confirm that the correct P/N for the screws is 6510175AA?
Thank you!
Ok, thank you! A couple of people here have listed that as the PN, but when I enter it in on the dealer site it says it does not fit my truck.I will try to find my packaging tomorrow in the garage and will update as soon as I can
I installed the liners without separating the rear pieces.Ok did the install today really easy... I did separate the rear 2 pieces and used the back one found an easy way to get them apart. I used a hook razor knife blade and cut slits in the part that comes through those holes then squeezed the cuts together... then I just used a long screwdriver to pry pieces apart oh and that little tab that’s on the rear that u take off.. broke the first one didn’t break the other side till I went to put it in then it snapped.... ugh. ..
Curious why folks are separating the two pieces as well.I installed the liners without separating the rear pieces.
I am not sure either.Curious why folks are separating the two pieces as well.
I have a Laramie and mine didn't line up properly with both back pieces, dealer actually installed initially. I uninstalled them myself, separated the two back pieces now everything lines up perfectly and snug.
I separated them because the guy in the YouTube video said to! It worked so....no harm done.Curious why folks are separating the two pieces as well.
