Rear wheel house liners
Are ya'll doing this for protection or so that the back matching the front? I want mine to match and thinking about painting the white with black under coating which would be way easier and quicker.
Both. It looks a lot better and it keeps crud out of places it would get without them.
I had a 2002 and 2011 Dodge/Ram 1500's without them, 2002 started to rust, nothing on 2011. My 2019 has them and it just sounded weird driving in the rain with water splashing off them. I don't think there is a correlation with the tubs and rust, but who knows.
The only rational thing that makes sense on why it isn't standard is that maybe its the labor to install them that is keeping them from being a standard item. Its sure not the cost of the plastic!
I thought they were standard.
AFAIK, they're only standard on Limited trucks.
They add a few pounds of weight, so they make it an option so they can list higher payload numbers. I really wish they were standard on all trucks - like others have said, without them the truck looks unfinished.
-John
They were standard on 4th gens now on 5th gens they are not. I made sure to order them on my 2019. I dought they add more then a 2 lbs to the truck as they are really thin.
Just ordered the rear wheelhouse liners and screws from MoparPartsGiant.com. With shipping and tax my total came out to $117.49. The shipping was only $16.28. That sure beats paying $112 shipping from RockAuto.com.
Just wanted to update everyone doing this install
I did both my liners today and I left BOTH front and rear two piece liners in place and put the full liners in over top of them. EVERYTHING fit perfectly! Also the new liners I bought came with new clips and bolts so I had everything I needed right at my hands
Just ordered from MoparPartsGiant with $17 shipping. RockAuto wanted $139 like someone said above, LOL
On Laramie the existing rear liner is two pieces that is supposed to be split apart and then you reuse the rear part of it. If you don't split the rear liner apart the holes don't really line up. Existing front liner you don't need to touch.
Check out this video
-John
Hope thats not their logic to increase payload. Heck remove the spare, that saves more...
On my big horn the rear was a 2 piece setup aswell but I didn’t separate them, I kept everything as factory minus removing the bolts and inserting the new full liners and reinserting the bolts.
For many years, that's exactly what the manufacturers did - remove spares, liners, bumpers, anything to get the magical numbers to work. Real world trucks weren't so capable.
-John
Like @Evilemokid94 my BigHorn install was slightly different (as follows) than this otherwise excellent Laramie video described:
- Needed to buy SIX EIGHT extra hex head screws, part # 6510175AA, $1 each, in stock locally
- Did NOT remove the rear inboard screw clip to shift it forward, since I re-used that mounting point to secure the rear backing piece (see next)
- Used the back half of the rear panel as described in the vid, but I reinstalled the screw at the inboard position for stability
- Reused a screw clip off the old front liner for the inboard center hole. Tapped it with a hammer to “lightly smash” it closed a tiny bit so it would stay put.
Other than that the video was spot on, and SUPER helpful. Liners in, took an hour or so.
-John
Das true, and they also tried the notorious “run flats” which were ot so hot on wear and high replacement cost...
Upstate NY here too, I plan on ordering my liners this week.
My 2007 1500 sport had them and still do with no issues. I just had the liners installed today on my 2019 Rebel
