faithwalker
- Jun 7, 2019
Mailman delivered the parts today. Install took maybe 45 mins. Love this upgrade! So much brighter.
I saw this, but the wire is black so I ran it over. You cannot see it unless you are inches away.Behind plate there are two push pins with no function , I removed one reamed it out (plastic) with screw driver and ran wite thru hole pulled grommet flush against. I have bighorn maybe yours is different?
You will absolutely love this upgrade. Post back with your thoughts once you do this.I want to thank everyone who posted step by step pics for this mod. Received my LPR today, installed and ready to go. Backing out of my drive at night has been a guessing game and now I will be able to see!!! waiting for sundown! Also waiting on VLeds license plate bracket which is on back order. This my favorite mod so far, lots of walkers and kids in neighborhood, now I don’t have to back in drive. Thanks again !
I have factory reverse LEDs, and while they’re fine most of the time, they don’t light up enough in pitch-black situations. This is the reason I went with the LPR. The difference is very noticeable.As posted prior, I have installed and it is great, however did anyone try to just replace their reverse bulbs with LEDs and what was issue. Diode dynamics lists reverse bulb replacements for the 2019 1500 for both LED or halogen from factory. $20 vs $100 plus wiring. Again I love this mod but did I jump on a pricey fix vs simple bulb replacement.
Yeah, I kinda figured the total lumens from the bar would be superior as well as a wider band of light vs two bulbs ( although DD offered some hi powered options vs stock), thanks for replyI have factory reverse LEDs, and while they’re fine most of the time, they don’t light up enough in pitch-black situations. This is the reason I went with the LPR. The difference is very noticeable.
I removed the silver heat sink, but couldn't figure out how to remove the assembly further. The black area appears to be a large circuit card assembly with the bulbs connected to the board.
Yep - I just checked mine. Doing the same thing...any ideas how to fix this?My VLEDs are hitting the tailgate when it is down. Anyone else had this problem? Laramie sport.![]()
For LED headlights, with non-LED tail lights, the backup bulb size is 7440.
For non-LED headlights, with non-LED tail lights, the backup bulb size is 921.
If you have LED tail lights though, that means you cannot remove/replace your backup lights at all.
I have not seen one truck that had LED fronts and halogen rears. I don't think they would do it that way.Well, no backup light upgrade to the stock bulbs for me. DD responded today and cleared up my confusion. They said:
What trucks come with LED headlights and non-LED tail lights? Is that a Laramie or higher without the Advanced Safety Group?
