Measure the distance from center of wheel to underside of fender front and rear... the difference in measurement is the size of kit you buy.Does the 4x4 and 2wd come the same height from factory, i don’t know if to get the 3inch level or the 2.5 level from moto fab. Can you guys help
No it is crazy how many different spring part #'s there are even for the ORP it is not standard across there were 4 or 5 different numbers for the orp alone , example my buddy has a Longhorn crew with orp I have Laramie orp crew we have different springs go figureMeasure the distance from center of wheel to underside of fender front and rear... the difference in measurement is the size of kit you buy.
Sorry Vader that was to andressNo it is crazy how many different spring part #'s there are even for the ORP it is not standard across there were 4 or 5 different numbers for the orp alone ♂ , example my buddy has a Longhorn crew with orp I have Laramie orp crew we have different springs go figure
Depends if you have the ORP or not. If you have the ORP, then I would. If not... should be good like the OP's truck.Do I really need UCA’s on a bighorn with a 2.5 leveling kit?
ORP?Depends if you have the ORP or not. If you have the ORP, then I would. If not... should be good like the OP's truck.
Off road packageORP?
Nope no off-road package on mine just bighorn sportOff road package
Did you replace your UCA's??I went ahead and installed the MotoFab 2.5" leveling kit on my 2019 Big Horn Sport. I had this kit on my 4th gen, everything I read said that 4th gen leveling kits will not work on the 5th Gens, but I am here to say they do. Install was the same as the 4th gen, and I didn't have to modify anything for the kit to work. As of right now, nobody makes a 2.5" leveling kit for the 5th Gens, and I didn't want to go with only a 2" from rough country because it still isn't 100% level with the rear IMO.. So I went ahead and purchased the MotoFab kit that I had on my 4th gen and gave it a try. I am very satisfied with how it turned out. The ride quality is great and still feels and drives like factory.
I ended up putting 285/60-20 BF Goodrich All Terrain KO2 Tires on my stock wheels. These tires ride soft and are quiet, just like factory. No rubbing, No trimming needed for this setup.
Here's a link to the leveling kit: https://www.amazon.com/gp/product/B00I5058AY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Here's a link to my install video:View attachment 3505 View attachment 3506 View attachment 3507 View attachment 3508 View attachment 3509
No, unless it has the ORP, if you do have ORP you can get the mopar arms for 2" lift which will correct your angles enough, they are 50$ a piece so not too bad. The ORP has about a 1" higher ride height from factory so the 2.5" spacer will turn into a 3.5" lift, Also something I found out is that the ORP doesnt have as much rake from back to front as other packages, meaning they say its 1" all the way around but it's about 1" in front and only around a 1/2" higher in rear than others, with all that being said if you put the 2.5"s up front with the ORP, you will need a 1/2" spacer for rear to make truck level the 2.5" will be nose high on the ORP without rear spacersDo I really need UCA’s on a bighorn with a 2.5 leveling kit?
You should be goodI just want to be clear. If I put motofab 2.5" leveling kit on my none ORP truck and it's a pavement princess I do not need upper control arms?? TIA
