Yes, I broke both tabs.One caution on removing the plastic trim from the lower bed behind the rear wheels.
In addition to the two clips and the screw, there is also a locating tab. The tab goes into a hole next to the rear clip.
That tab is fragile...ask me how I know!
Also put the liners in without separating the rear pieces. I removed the front but on the rear, I just removed the screw around the flares, loosened it a bit, slipped it in and replaced the screws.
