Jhill
The Magnaflow cat back system tends to be out of alignment with bumper cutouts. Several of us used small- medium stainless steel screw hose clamps on the steel hanger rod to hold the rubber block on hanger biased in direction needed. Just use big set of slip joint pliers (water pump pliers often called) to shove rubber block in needed direction and add clamp to hold it and tighten up. Takes all of 5 minutes.I had a local mechanic install a Carven Cat back system the other day. Sounds awesome but the tips are not centered in the cut outs. Has anyone else had a similar issue? Any ideas how to get this corrected?
