Gman
Can we please talk about something a little less controversial...like politics or religion?
Another video from EE:
Does it need the pressure? Why not just vent to the air with a filter on the end?
As far as the catch can, it needs to be air tight because it is directly connected to the air intake after the air filter and would allow destructive contaminants from the engine bay almost directly into the cylinders if it leaked.I was told that system needed to be sealed for it to function correctly. That is why all the fittings need to be air leak-free and gaskets on the can sealed correctly. If someone gave me bad info then let me know. I can't speak for a diesel engine but was told this for gas engines.
Now I'm wondering how much the filter will restrict airflow as it becomes soaked in oil over time....especially with all the sensors that detect anomalies in airflow to/from engine.
I installed a double oil catch can setup. Silver one off eBay ($53), black one off Amazon ($19). Pulled 6500lb trailer thru mountains in AZ, 700 miles produced about 1oz oil.
Why do a double???
I saw a video with a guy that ran 2 catch cans to compare and determine if one was better than the other ( RX Performance Vs. Moroso). The $53 ebay had a plastic baffle in the top filled with aluminum shavings. I really didn't like the design, then saw this $19 Tasan on amazon that had a design like the Mishimoto. So for $19 I wanted to see if one would catch more that the other. My findings, after 700 miles there was about an ounce in the ebay can and nothing in the Tasan can.Why do a double???
ebay can...
Tasan can...
