Ok. So for anybody thinking about a Bak Revolver Tonneau. Here’s some first impressions:
The good
1. Generally well designed and made.
2. Fits nicely and looks clean and slick
3. Packaged well and good directions including specific sheets related to RamBox install.
4. Shipping was fast 3-4 days. (I bought from Tonneau Factory Outlet (Morrie).
5. The install was pretty simple and I did it in a couple hours on my own.
6. The RamBox lids open and close nicely. No interference.
The not so good:
1. Maybe you’ve heard about difficulty sliding the Bak rails into the factory rails .....yep. So that’s because although Bak did a heck of a design job on the rails and how they interlock (no, really they did!)
BUT. They apparently didn’t give the guy drilling for poprivets a jig to ensure perfect positioning. So of the 10 poprivets in my two rails, 6 of them were not seated correctly because they were positioned off center.
In the second photo you can see one of the four that were in correctly.
So I drilled out the 6 fails, redrilled new holes and correctly riveted them. Both rails slid in perfectly without any lubrication pounding or coaxing. Perfect fit.
The protruding heads on the misaligned rivers grind on the factory rails so sliding them in would have been very difficult.
Anyway, could I have sent it back? Sure, but I’d have no confidence that the rivet guy had gotten that alignment jig yet!
So the replacement probably would been just as bad. Maybe even worse. And otherwise I like the tonneau. So, I did the mod myself and it worked out fine.
2. I still need to do a bit of weather sealing in the two front corners. Those spots could use a bit more design refinement, but I believe it’s solvable.
3. And the area on each side of the tailgate will likewise need weather seal as others on this thread have noted. Again solvable.
Hopefully this is helpful.
