I think I like the clean look of this revolver even more than my bakflip mx4...And one more pic:
That is why I purchase it! it looks MEAN and CLEAN. and the bed access is the best part.I think I like the clean look of this revolver even more than my bakflip mx4...
Guys! Can the tailgate be opened/closed with the revolver closed?That is why I purchase it! it looks MEAN and CLEAN. and the bed access is the best part.
thank you!Mine opens and closes with the cover closed with no problem.
I installed my RevolverI think you’ll like it.
No issues at all with the RamBox doors. They open and close freely and stay open if left up.
The closure lever is smooth and has nicely rounded corners. Could you catch it and bend it? Probably. But, I think if you are aware it’s there you should be fine. In the second photo I circled the lever with the cover rolled back a bit.
Ordered a BAK Revolver X4 from Morrie today. Looks like it will arrive before my truck.![]()
I installed my cover yesterday and was pleased that I didn't have the issues others have had with the driver side rails. It took about an hour to install and still needs a little adjustment, I was racing the rain. Overall I'm very pleased with it and it looks great.
Did something similar
I just ordered this. Going to give it a try and see how well it works.I just used a universal one from Amazon that you cut to length yourself. Ill grad some pics later today.
https://www.amazon.com/VERGILIUS-Adhesive-Universal-Stripping-Tailgate/dp/B07HJWXN97/
EDIT: Also I always clean surface with Isopropyl alcohol and then use 3M Adhesion promoter.
