Patsy1099
 - Jan 5, 2019
- Location
 - People’s Republic of New Jersey
I have begun my upgrade from the stock 6 speaker. I just installed Infinity Ref-3032cfx 3.5 in the dash (3ohm) and Ref-9632ix in the doors (also 3ohm, going in soon). Everything will be checked for polarity and be wired in phase, regardless if it messes with the ANC (I will disconnect if need be). I had to correct one of the dash and metra harnesses already.
I am not sure if I will do an amp or sub afterwards. It depends on the sound of the speaker upgrade and also whether or not I can do something relatively simple. Don’t want to get too crazy.
I have a couple of questions. I’ve read that the dash and front doors are wired in parallel. If I am considering the possibility of doing an amp, should I run some speaker wire now to the front doors so I can put them on their own channel and run the dash speakers as mids only? Or am I understanding something incorrectly?
I have read this entire thread 2-3 times but am still confused on some things including whether the ANC issue is understood and corrected and if Maestro of anything else makes a clean plug/play solution.
Can @WRH @YoAdrian or anyone else comment on the above? Any suggestions on amp solution that will be the easiest install from a headache standpoint? I don’t mind disconnecting stuff and rewiring but I would prefer to do things once and not have to rip things apart again. I also don’t want anything that will be glitchy or give me headaches with things not working. I prefer it as bulletproof as possible.
Thanks guys.
Thanks guys.
