NorthCountryEvo
Chevy 78.1Are they Chevy 78.1 or 77.8 Ram?
Here is the link to exactly what I bought:
https://www.amazon.com/dp/B07C9ZFB4H/ref=cm_sw_r_cp_api_i_SZZ1CbP2QG2Z1
Thanks for the info, appreciation! I think I'm going to try and get the exact 77.8 diam Ram spacers in 1.5" depth. I know 0.3mm is barely a "C" hair, but I'm one for following spec... even if it means waiting or paying more.Chevy 78.1
I agree. Bora is likely the only brand I’ll consider. My reading on the spacer materials is that aluminum is better for daily driver/low stress/high speeds where steel is better for high stress/lower speeds (think rock climbing).Be wary of cheap aluminum spacers, I've read reports of them cracking.
Your truck sure has a nice gloss to it. The first picture can't even see the truck.Installed 1.5" Yitamotor spacers yesterday...
Before:
After:
Great pics, nice truck! I was between 1" and 1.5" but your pics are swaying me more to 1.5". The tires look like they're perfectly in line with the flares now.Went out quick while at work and took a couple pics of my truck with the 1.5 Yitamotor spacers from Amazon. I can't speak to the 78.1 vs. 77.8, but I know that the 78.1's fit very snug, and everything is still tight after a week and about 200 miles. I was unfamiliar with spacers in general prior to adding these, and everything I can find seems to lean towards them being fairly same for everyday driving if aluminum, and that a large majority of issues come from improper installation and torquing.
Hope the pics can at the very least help some people decide if they want 1.5's, less or more.
^^^ I was thinking exactly all this.Great pics, nice truck! I was between 1" and 1.5" but your pics are swaying me more to 1.5". The tires look like they're perfectly in line with the flares now.
I agree that 90% of peoples issues with any mods is bad installation. That being said, I personally don't want 0.3mm of material to be the reason I'm in the ditch. Just a personal preference/paranoia.
NO sensible reason to install/promote 78.1 lugcentric spacers...akin to aftermarket wheels minus hubcentric rings...both poor choices.
Lugcentricity/increased stud load can lead to vibration, cracked studs or worse.
OEM wheels are hubcentric...why tempt fate?
COYOTE > (3) 77.8 hubcentric Ram DT options or ya can $pend double on Bora
Buy NEW wheels for that wider stance...infinite options that won't break the bank.
OEM wheels...beyond boring
I can vouch that the 78.1 fit snug against the ram's 77.8 wheel bore. I purchased the 2" hubcentric spacers which were 78.1 and even I was skeptical myself and sure enough they fit snug. Like "safe snug".I get that you are promoting safety, and I’m not trying to have an argument, but I have to ask to ensure: are you 100% positive about 77.8 actually being on the truck? Because I bought my spacers based off of this post specifically, and with the back and forth between 77.8 and 78.1 I went and used my digital caliper to measure beforehand, and I went and checked a bit ago with another set of calipers from work (I work with aviation maintainers, so all tools are regularly calibrated) and both times I was getting just barely over 78 (less than 78.1 but I don’t remember the exact decimal readout). Also, cursory searches on the internet show the 19 RAM DT having 77.8 and 78.1 through different locations. I want to stick to spec from FCA, but I can’t discount that real world, on my truck, i’m getting right at that 78 mark.
Can anyone else check and see what they are actually seeing on their truck?
As do mine.I can vouch that the 78.1 fit snug against the ram's 77.8 wheel bore. I purchased the 2" hubcentric spacers which were 78.1 and even I was skeptical myself and sure enough they fit snug. Like "safe snug".
Completely agree, there is no need to put extra stress on studs which they are not designed for.NO sensible reason to install/promote 78.1 lugcentric spacers...akin to aftermarket wheels minus hubcentric rings...both poor choices.
If “close only counts in horseshoes & hand grenades” then why are my two separate readings with digital calipers only close the the 77.8 AND 78.1?absolutely 100% positive
78.1 fits GM trucks...you followed a thread of misinformation...close only counts in horseshoes & hand grenades
