This was the last thing I needed to pull the trigger on the Mishimoto lol thanks for the post, it put me over the edge.So I wanted to show you guys this hemi with 90k miles on it. This is the intake ports, and like I said when I took the intake off you could pour the sludge out.View attachment 65166View attachment 65167
"molecular separation and angular velocity" is commonly researched in engines, why do you think fuel injectors have changed and are more precise? why is direct injection more powerful than port? why are exhausts not square corners? why would you "Port and polish" an intake where the roughness of the inner and outer path are different? Why is a dry sump the ultimate go-to oiling system? all of those are real world proven evaluations of "molecular separation and angular velocity" wizardry
Im not saying your corvette is a bad build. I enjoy the sound of a nicely tuned engine and drivetrain. and again... as you realized, not all parts work together. you may have had an overly restrictive catch can, never denied it, and its great to have the input that you had a bad experience with one, so others can know what to watch out for.
BTW there is probably a v6 mustang with an underdrive pully kit that said he can beat you![]()
No egr, replacement engine was the same. Good thing i pulled the intake on the replacement because the previous owner did an mds delete kit to ot. That would have made things interesting.@JCebula does that truck have egr? Just curious, that’s a good amount of build up.
What's the deal with the air filter? Seems like it would interrupt the vacuum from the intake being able to draw off the crankcase.I have this system on my Corvette, gonna buy the same for the truck
Ram Gen 4/5 Hemi Mild | mmsolutions
PCV can set up with -8AN Fittings-connects between PCV valve and intake manifold-includes mounting kit, required push lock hose and -8AN fittings-if you do not think this mounting kit or fittings are best for you install, please go to the 'Build-A-Kit' section following this parts list as a...www.mightymousesolutions.com
It will not and you'll be just fine. It is all vacuum based and it will get sucked through just fine.So my question is, will running the tube up and over have any negative effects on air flow into the catch can or cause build up in the hose?
Way overpriced OCC and a bit "gimmicky" too. It will perform no better than the Mishimoto.What's the deal with the air filter? Seems like it would interrupt the vacuum from the intake being able to draw off the crankcase.
Thanks for the reply. I ended up adding some heat wrapping to the hoses and ran them underneath. I didn't like the look of it going over.View attachment 66260
