Bye bye Pulsar
Hello Pedal Commander
Attached is a side view ( I think this is what you are asking to see) I took a pic with only the rear lugs switched to black because I was running out of daylight and I also thought it might be good to see the comparison. Black lugs definitely look better IMO. I am also throwing in a couple of other pics, one at an angle and one of the wheel close up with the black lugs installed.
Gorilla black lugs ordered!
You might want to return them and try McGard. I went through two sets on my F-150, they start to rust from under the black coating. I even waxed one set and they still did it.
Bye bye Pulsar
Sorry if this has been asked already but is the PC better or just different?
The PC solely enhances the throttle response. I love what it brings to the table but for my needs it wasn’t utilized to its fullest. I swapped out and went with the Sprint Booster...
Care to elaborate?
Meaning when you press on the oem pedal currently there is hesitation. After installing The Pedal Commander depending on which setting you use, it now runs like a scalded cat. There is NO power gain before anyone wants to jump in and slay this. Effectively what’s its doing is removing the delayed response time. If you need the tech specs, you can always contact them and they will gladly walk you through it. :)
Installed the pro clip mount today. Works well and suits my needs. Definitely recommended!
I put Pro-clip mounts in all my vehicles. Love the one that mounts at 1-2 o’clock in relation to the steering wheel barely have to take your eye off the road when using the phone for navigation.
Installed my OEM mud flaps
This slide really takes the bed cap to the next level. It's 4' wide, so it can accommodate a full sheet of ply. You only lose about 1/2" front to back, but about 5" of unfortunately.
This HPI bedslide can handle 2,000lbs fully extended! So, needless to say, more than the bed itself can. I found it used and while it's 10 years old, a little grease on the bearings and its as good as new.
No, I want real world impressions, like yours!
I'm wondering how much these things affect the MPG, other than the "lead foot effect".
Oh lol for myself I really never checked on what it did to my MPG. I’ve found throughout my years if I don’t want variables to change, then I definitely don’t mod. :)
Doest the tip have much effect on the exhaust note? How does it sound?
sman301 sman301 sman301
No noticeable change in sound, just fills up the exhaust cut out more and a nicer finish with the double wall
Installed Dawn Enterprise's Door Edge Guards. Charcoal color matches Granite Crystal nicely.
"SlimLine Door Edge Guard; 16' Roll - 3/8” Wide, 1/8” Thick / DGAR16-HG
- Extruded Molding Color: 40 | Charcoal"
I put some Winunite door edge guards on today. Just enough length to do all four doors and took the extra and did my tailgate.
Winunite Car Door Edge Guards... https://www.amazon.com/dp/B07FTFKB4G?ref=ppx_pop_mob_ap_share
Match up pretty well. Hope it helps out, given there are no door moldings on this Black Out package.
I bought my new Ram a couple weeks ago ... so far I’ve put on the x15 cover, new floor mats, installed Hikari LED headlights and fog lights, and replaced all the halogen bulbs on the inside to LED’s. So far I’m into these additions for about $650.
Got most of my information and decisions answered on these forums.
So far I’m loving this truck ... been a Chevy guy for 25yrs!
