securityguy
I don't see any red cars???i don't like red car in you background (behind your car in picture)![]()
Attached is a side view ( I think this is what you are asking to see) I took a pic with only the rear lugs switched to black because I was running out of daylight and I also thought it might be good to see the comparison. Black lugs definitely look better IMO. I am also throwing in a couple of other pics, one at an angle and one of the wheel close up with the black lugs installed.
You might want to return them and try McGard. I went through two sets on my F-150, they start to rust from under the black coating. I even waxed one set and they still did it.Gorilla black lugs ordered!
Bye bye Pulsar
Hello Pedal Commander
The PC solely enhances the throttle response. I love what it brings to the table but for my needs it wasn’t utilized to its fullest. I swapped out and went with the Sprint Booster...
A little Gtechniq and some vinyl work
Doest the tip have much effect on the exhaust note? How does it sound?Put the Mopar 5" tips on, part # 82216079AA
View attachment 40750View attachment 40753
I put Pro-clip mounts in all my vehicles. Love the one that mounts at 1-2 o’clock in relation to the steering wheel barely have to take your eye off the road when using the phone for navigation.Installed the pro clip mount today. Works well and suits my needs. Definitely recommended!
Meaning when you press on the oem pedal currently there is hesitation. After installing The Pedal Commander depending on which setting you use, it now runs like a scalded cat. There is NO power gain before anyone wants to jump in and slay this. Effectively what’s its doing is removing the delayed response time. If you need the tech specs, you can always contact them and they will gladly walk you through it.![]()
sman301 sman301 sman301
Installed Dawn Enterprise's Door Edge Guards. Charcoal color matches Granite Crystal nicely.
"SlimLine Door Edge Guard; 16' Roll - 3/8” Wide, 1/8” Thick / DGAR16-HG
- Extruded Molding Color: 40 | Charcoal"
