I wanted to install the Dynamic Diodes SS3 Fogs in my 2024 Ram 1500 but I didnt like the lights that Dynamic Diodes had for the 2024 w led fogs so I ordered the lights I wanted and the bezels. I noticed the light and the bezel don't appear to mate properly. I ordered the bezels myself, part #68318117AB. Is this how they are supposed to fit? Thanks for the help. Rick.
you may want to try the "DD"after all.since they are made for that area of your truck....Just my "0.02$"
You don't need multiple threads on the same topic. :)
So climbed under the truck and knocked the Vice Design skid plate to check out my front axle lock actuator connector and wiring, since that's what the dealer said was wrong. I didn't see anything wrong with the wiring or connector. But did notice that the actuator housing was loose. There are three digits that hold the area the connector plugs into, to the main body. That piece was loose. I was able to squeeze it back together with some channel locks. Haven't test driven it to see if that will fix the issue or not. Next step, I guess would be replacing the actuator itself.
Nothing special swapped AJT cases since the old one has taken a beaten
IM CONFUSED BY YOUR POST... DID U ORDER THIS KIT??
Put some husky mudflaps on the warlock today. You would think with the tire option that comes standard on these they would be included.
You don't even have elfender flares, and I don't know a single vehicle that has factory installed mudflaps. If anything the dealer will add them on before selling.
Nope no flares on the new warlocks which is fine by me . If the tires were out past the wheel wells they would be usefull but that's not an issue on the stock setup.
hopefullyy that fixed it!
in their signature
"2025 Ram 1500 Laramie Sport, 3.92 gears, Bed Utility Package, Rough Country Tow Hooks, Lomax Tonneau Cover, Xpel Tint, Xpel PPF"
FWIW when I am on my phone I do not see a sig unless I open it up.
