Hell to the Yes!!!!!!It is wired in with a power actuator. Turn it off for the highway for a nice quite ride and then open it up for tunnels and passing mustangs.
Rampat,Let me know how you like the hellwig!
Rampat,
DEFINITELY worth the price of admission!!!! Big difference in the "feel" of the truck. First I installed just the Hellwig to the middle setting (3 total settings). Took it safely through some curves/turns/bumps when no cars were around. Like the yield lanes we have here in Florida(you know) that go around the curve to allow you onto bigger streets to then merge into the flow of traffic. My My My...she was tight and followed her nose around the curves/turns with virtually no outward lean/swaying. Compared to stock, I have to say night and day difference.
With a little Autocrossing in my background with my old BMW...you learn how to attack curves and drop into them appropriately to avoid spinout and max acceleration...basically get the feel of the weight shifting etc along with how to properly use your brakes and so forth---I would love to get out there now with my truck. Yes, I know the truck is not a racer but still would be fun. At the course in my area that have allowed trucks on the course.
I know this is a very subjective statement---going from stock to Hellwig rear sway bar AND adding my 2" wheel spacers (littler wider in the rear now); it does feel like I went from the go cart lean to the "rails" around the curve in my truck!!!!
I would imagine those with the airbags and/or other improvements of the suspension along with the Hellwig are really enjoying the tighter feel probably steps above my Bighorn.
Now, If I can find some better brake pads (noooo not a brake kit--no big brakes) I really would be complete with my RAM19 until BMW made a truck!!!!
I definitely recommend getting the Hellwig no question about it.
Trying my luck with a new weather seal for my Mopar bed cover. Disappointed in how much rain has been getting in with the original seal and set up. Saw a while back another member used it around his tailgate/Rambox area. Bought it on Amazon. I also used a little waterproof sealant glue on the screws that go into the cover’s rails which hold a small bracket for the arms to hold the cover open against the cabin. I think the brackets leak because they're accidentally screwed through the rails from the factory. Hopefully this work keeps more rain out.
I applied the seal to the bulkhead AND the cover itself. But it ended up being about 1/2 inch too wide to properly close the tailgate. After cutting half the cover seal out it fit much better.
I used two small pieces from the original seal that were still sticky enough and put them at the back of the bed rails by the gate to see if it keeps water/debris out. Fingers crossed that all this works out better than it has been or else I’ll need some waterproof luggage!
Oh and I cleaned the tri-fold with Chemical Guys waterless cleaner that I’ve been trying out.
I’m very interested in the rear black ones you installed. Those look robust, please report back on that.
Thanks Viper67, I will look into those EBC pads!!! How would you describe them over the stock pads?Good post. I’ll be doing the hellwig as my next project. I use EBC pads and rotors and love them. Ran them on my 3500.
What are your thoughtsI’ll do a review of everything that I’ve had installed exhaust wise later today. What has been installed today is a Mopar cat back paired with my Carven black tips. Definitely has a nice sound to it and one that I’m sure my wife will be accepting of.
What are your thoughts on the mopar exhaust so far? I'm trying to decide if I want to get it or the borla stype.I’ll do a review of everything that I’ve had installed exhaust wise later today. What has been installed today is a Mopar cat back paired with my Carven black tips. Definitely has a nice sound to it and one that I’m sure my wife will be accepting of.
I really like it but to be honest I know you can replicate the look and sounds much cheaper. I personally wanted the peace of mind that if something goes wrong, it falls on them.
[/QUOTE
I was thinking the same thing as far as warranty troubles. I have the b2 fabrication magnaflow on mine now ,its quality workmanship but it isn't quite loud enough for me. Is the mopar as loud as the borla stype?
I don't mind brake dust if its an improvement on the bite and braking as it is worth it to me.
