Land Surveyor
- Jan 5, 2021
Yes,2019 RAM 1500 Laramie
33,500 Miles
Pickup is currently at the dealership after a star case has been opened.
1000 miles ago (1 week ago) I took my RAM to the dealer because the outside shoulder on my front right tire was excessively worn. A technician looked at it and confirmed that their was nothing mechanically wrong and the alignment was within factory specifications, tire pressure was at 35 psi. Two new tires were put on the rear, the front ones junked, and the ones in the rear (which had good tread) were moved to the front. During next 1000 miles (1 week) I monitored the tire pressure of all four tires and they all stayed consistently 36 psi. Truck drove straight as an arrow like it always has. I then started to notice that the outside shoulder of the front right tire was already starting to wear. It is currently at the dealership until further notice because everything appears fine and they are unsure what is causing the problem. The dealership is waiting for assistance from Chrysler.
Is anyone else experiencing this?
I just had the same exact problem. Front right tire excessively wearing. (2019 Ram Limited, 28,500 miles). Brought to McKays Crysler, Jeep, Dodge in St. Cloud, MN and they said alignment was in check. They said they had never heard of the problem before and blamed it on bad rubber on the Bridgestone Dueler tire. They also, told me nothing is under warranty and said I should get new tires. Unbelievable. Anyone else seeing this since this post in 2019?
