mdirads
I did a Factory Reset, but it did not restore the mirror cameras.
Yes, PROD is on the end of mine too.FCA-MY23.T25.48-PROD is whats mine is saying everyone have the "PROD" on the end? I havent seen any issues yet for mine Knock on wood as I have been dealing with a radio issue but I am thinking I have it narrowed down to the USB hub, if I have a thumb drive in the drivers side I get issues havent seen any in the passenger side USB yet of course dealer wont replace the media hub until "THEY" can reproduce it even though I show them video after video of it doing its flashing thing not good enough for them I should have kept the F150
All updates are OTA only. Only time we get USB files is someone who has direct access to Ram's files because Ram think's consumers are dumb and want to limit our ability to service our trucks. It's the same reason we can't revert to older firmware for people that are having problems.T25.48 Update is thru OTA only or some one can share USB update.
Probably because too many letters. Shorter file names are better then longer if at all possible, if anything it would change to some abbreviated forum of Stellantis. That likely would also not happen until UC6 happens, as changing the the start of file names on an existing project is blah and could cause headaches for support people (I forget Ram doesn't provide support so I guess that part doesn't matter LOL).View attachment 163791
Question…….why does the update still show FCA when Stellantis took over?
Mine was like that and nothing worked till I did a reset then back to normal.I think the icon is slightly different to the left of the driver's steering wheel/seat control. Appears to be red and blue? Possibly to indicate that's where you adjust temperature?
Sent from my SM-S918U1 using Tapatalk
Ah, ok. I was able to select my existing profile and the little bit I tried so far seemed to work.Mine was like that and nothing worked till I did a reset then back to normal.
After reset
YesWas the shortcut pull down always there at the top? I never noticed it before.
I do not have AlfaOBD (have been considering it, though), and I'm missing my side mirror camera views on my 22 Longhorn since the update.Does anyone posting in this thread with the missing side camera soft keys have AlfaOBD. I’m pretty sure I know what’s going on with that.
Scratch that...it changes to the Vehicle screen about 1 in 3 starts...so bug not fixed, just changed.One bug I noticed seems to be fixed - when starting the truck, the UConnect would always revert to the Apps screen. Now it stays on the Home screen as it should.
I've noticed the same thing. Seems like the first start of the day does not go to home screen. Then home screen after thatScratch that...it changes to the Vehicle screen about 1 in 3 starts...so bug not fixed, just changed.
Thanks for the tag, n8zcc,Same here.
After the update and reboot, I lost audio (no sound) and Android Auto. Later in the day, I ran to the store and the audio was back on but still no Android Auto. Two days later, the Android Auto ICON shows up and I had to go through the initial setup, after that everything is back to normal.
These OTA updates scare me, seems something is always broken or missing after the update as you sit there, fingers crossed, hoping all your settings and features will return unharmed.
@RamCares
Perhaps you can take a few minutes to post a list of the changes the update brought since the changes page wouldn't load.
