Anyone have problems with the exit menu command? Left arrow and tap res buttons.
Mine will not exit, I just hit cruise off and it gets rid of the menu. But it keeps the menu location saved so when it starts back to it goes back to where I left off.
I read somewhere someone said you have to go to the very end of the menus (after version display) but it doesn't state that in the manual. It reads in the manual like it can be done at any point.
Also, light show question. I have C2 set like this.
- Left Fog then right fog (5x and fast)
- Rear backup left and right (3x and fast)
- Front left low beam and front right high beam (3x and fast)
- Front right low beam and front left high beam (3x and fast)
- Rear backup left (5x and fast)
- Rear backup right (5x and fast)
Now my concern is this. When the truck is running all lights run at full power and looks great. Headlights are fully lit and flashing but....
Once I kill the power to the trick, my headlight flashes are reduced in power. Like a very quick low flash light. All other lights (fog and backup) at full power.
The wired part of all this is , first that the headlights are at full output when truck is running. But the other part is any of the pre-loaded light shows when truck is off the headlights are at full power, albeit they do not flash at the same rapid speed at my program.
Could the speed of my headlight blinking (3x and faat) and truck turn off be the reason? If so why? I believe the pre-loaded light shows have all the headlight commands set to "on", I don't believe as any of the 6 pre-loaded command the lights to have rapid blinks. Anyhow thoughts?
